Freshly Rebuild engine, ticking noise and low oil pressure
Solved
so the shop, which did originally the engine rebuild kept te car over winter and last week they called, that it is all ok now. They changed few valve seats, oil pump, chain tensioners and ALL piston squirters. Now oil pressure is in spec and engine is quiet. No Ticking!!!
5500 Euros lighter but happy
We believe, that squirters were the only problem. When they leak, the oil pressure within the system is not high enough to pressurize the lifters on idle
Nadim
all goog then, congrats
it would be great if you could post a similar video of engine idle to see the difference before ( engine ticking video above) and now
there you go from today
Nadim
https://youtube.com/shorts/an2oJRtQRhg?feature=share
