Foam cannons - anybody use one?
Foam cannons seem tempting.
Hooking up the pressure washer is a PIA.
Any use a hose driven unit with good results?
It seems a lot easier than the typical bucket/rag technique.
About 50% of Amazon reviews are fake, so I don't really trust them.
Gbos1 (03-25-2022)
I have had one for a few years... Purchased on Amazon for about $40. Chemical Guys brand.
I've had to replace the O ring inside the gun but, otherwise, works pretty well.
Hooking up a pressure washer is a PIA… really? My 2000psi electric has wheels and weights less than 30 lbs. Adds less than 10 minutes to set up and clean up time. Benefits the condition of your paint, which being a Porsche owner performing your own washing, you must care about. As usual though, to each their own.
c2_peter (03-24-2022)
I've been doing the two bucket system for 2 decades but always willing to consider better alternatives. Have my eye on a bunch of ammonyc stuff right now because Larry seems a good dude to buy from. I like his youtube content. I finally pulled out and used the Porter Cable orbital polisher I bought in 2001 or so and was too scared to use because of Larry's stuff making me comfortable (and I bought my 16 year old an old accord with crap paint so I had something to learn on). Results are great
The thing I can't get my head around on the foam method is not rinsing off the grit first. Not sure I trust it
I am reluctant to use my pressure washer in general on the 993 because:
- more likely to push water under the windshield seals
- at times, it will knock off a wheel weight
97c2s993 (04-04-2022)
OP I'm with @Gasgasrider I don't know what pressure washer you own but many are compact and very easy to set up; well worth the extra effort to prevent swirls and scratches from the traditional sponge/bucket method alone.
I use the two-bucket method along with a pressure washer and foam cannon. Does Larry (AmmoNYC) not rinse off the with pressure washer before foaming? If so I'm a bit confused as to why.. It only takes a couple minutes to rinse off grit with a pressure washer before foaming and would prevent unnecessary micro scratches.
The following 5 users liked this post by VadGTI:
flyingchappy (04-04-2022),
JB 911 (03-25-2022),
Kein_Ersatz (03-25-2022),
KingTubby (05-11-2022),
sacman (03-28-2022)
Been doing the 2 Bucket system for years. Works Excellent. Hooking up my pressure washer is a PITA and for what? Some dust on the car! Not like your out Mud Bogging in your 993!
The following 5 users liked this post by boomboomthump:
c2_peter (03-25-2022),
GD993C4 (03-26-2022),
Jon 'Bama (03-26-2022),
VadGTI (03-25-2022),
YellowDieselGolf (03-26-2022)
Blow dryer is a game changer
Used the hose hook up one for a bit but didn't work that well. Got a foam cannon for the power washer from Chemical Guys and it works great. Hooking up the power washer can be a bit of a pain sometimes but it's worth it for me unless i'm in a real hurry.
I always pull out the leaf blower after, helps a ton!
