Who rebuilt your dual distributor?
Due to the limited access to the proper parts or a poor assembly process, the dual distributor in our cars may receive a less than satisfactory rebuild from a durability standpoint.
Also, a key rebuilder has retired and is no longer providing rebuild services.
I am looking to compile a list of services that have produced a reliable distributor rebuild.
I would like to know of any who had a rebuild that was problematic.
Any feedback from the Rennlist community is greatly appreciated.
Andy
Andy
M. Schneider (05-08-2022)
The faint noise you hear,,,, is 964/993 Ignition distributors going over a waterfall .. An excellent distributor rebuild resource "Wanted".
Have been meaning to service the 993s distributor .. So much for procrastination ..A tier-one, now retired rebuilder was in my own backyard. Damn.
I assume you're meaning Steve Weiner retiring? I had him rebuild mine 3 or 4 years ago. I am certain Rothsport can reliably rebuild your distributor. They're still open....
-Scott
-Scott
I had Steve rebuild mine previously, but I've also heard really good things about this guy- https://www.ebay.com/itm/272868674556? Looks like he's done everyone's in the EU-
C.
C.
M. Schneider (05-09-2022)
Seared
Interesting. Just read through his description of work. Seems very comprehensive.
Andreas
M. Schneider (05-10-2022)
Patrick Motorsports did mine. I think they may have the parts available too for purchase.
I rebuilt mine with all new bearings, belts and everything 11Kmiles/2 years ago. Just rebuilt my alternator, same deal - all new bearings, slip rings, regulator etc. Going to do my starter next. Once you get the hang of pulling the bearings off, reassembly is easy with a 10 ton press. After reading the horror stories of refurbished parts from Bosch etc, I like knowing that EVERYTHING has been renewed and I'm good for the next 100k miles with essentially a new original part.
The following 3 users liked this post by IainM:
-Scott
Did mine myself as well. Just replaced the belt but pressed everything apart. Bearings looked to be in nice shape but dry so cleaned and re-greased. Cleaned/lubricated the advance mechanism as well.
IMO it was easier to rebuild the distributor than getting the damn thing out of the engine
My initial thoughts are try Tony @ Callas Rennsport. Even if he doesn't do them likely he's got a recommendation.
I rebuilt mine recently without replacing the bearings. 96k miles and it looked original. Belt looked ok - my distributor had the air vent. I cleaned the bearings and re-greased them. It should last a while. The hardest part for me was drilling out the pin with hand drill and also mushrooming the new one in there. There is a document floating around with details and pictures on how to DIY.
https://www.pff.de/wcf/attachment/36...anleitung-pdf/
I just looked at my old receipt from Rennsport Solutions, and damn, those bearings are crazy expensive!
The following 2 users liked this post by Coleman:
M. Schneider (05-10-2022),
serval (05-19-2022)
