993 Forum 1995-1998
Sponsored by: DashLynx
HIDs pop when turned on...help please!
Old 03-26-2003, 01:51 AM
  #31
swftiii
swftiii's Avatar
Post
I tried wrapping all the wires in aluminum foil and it didn't work. I didn't try wrapping the balast or igniter, but will give that a try next.
If I move the amp under the passenger seat, do you think this would speparate them enough to solve the interference.
Amp-993C2 - what were some of the difficulties with mounting the amp under the passenger seat? How did you mount it - screwed into the floor?
Thanks guys
Old 03-26-2003, 02:12 AM
  #32
Eurocarguy
Eurocarguy's Avatar
Post
Although I know you tried the aluminum foil shielding, I did forget to mention to make sure that the foil is grounded. This is an important point. So if the foil wasn't grounded, I would recommend doing that test over again. Wrap foil around all the lines from the ballast and even around the ballast. You could even bring it over the back of the head light reflectors. If radiated EMI emissions from the ignitor is the cause, a grounded metal shield will definitely attenuate the emission. Also, since you have the foil roll out, shield the amp and its wires' too, and ground it to the chassis ground.
Another engineer at my work suggested separating the ballast and amp grounds as far apart as possible in case transient ignition emission is being conducted by the amp's ground. Personally, I doubt it, but it is worth trying just to eliminate the possiblity.
Solving EMI problems is a step by step process, but ultimately I think you will solve it. (I remember a few years ago we had one light source that took 2 engineers a month to make pass EMI, so sometimes it can take awhile)
Old 03-26-2003, 02:22 AM
  #33
Eurocarguy
Eurocarguy's Avatar
Post
One other thing, try to make the wires between the lamp and the ignitor as short as possible in your installation. My experience is the less wiring running around, the better. I'm under the impression that the ignitor and ballast are in the same housing. If not, move the ignitor right next to the lamp.
Old 03-26-2003, 11:33 AM
  #34
swftiii
swftiii's Avatar
Post
How do I ground the tin foil? Just make sure it is touching metal?
Skip
Old 03-26-2003, 09:55 PM
  #35
914und993
914und993's Avatar
Post
If the foil is touching bare body metal, it is probably grounded, but maybe not well. There isn't much grounded bare metal in that headlight well, so I would take some bare copper wire, attach it to your normal grounding point, and wrap the other end of it 4 or 5 turns around the foil sheathing.
Chip
Old 04-26-2003, 03:31 AM
  #36
swftiii
swftiii's Avatar
Post
Ok everyone I thought I would give you an update.
The pop was because of the crappy becker stereo head unit. I replaced it with an Alpine and the pop has gone away.
Thanks again for all your help and I'm very pleased that this has resolved the issue.
Skip
Old 04-26-2003, 04:07 AM
  #37
Randy M
Randy M's Avatar
Post
Skip, I have the pop now.
Old 04-29-2003, 01:11 AM
  #38
swftiii
swftiii's Avatar
Post
Randy -
Sorry to hear about it - did it just start or was it always there since you installed the HIDs?
If it has always been there, what stereo system do you have?
Skip
Old 04-29-2003, 01:16 AM
  #39
Randy M
Randy M's Avatar
Post
Ever since the HID install. I have a CDA9813 Alpine deck and an old Alpine 3525 amp. The pop is not too loud. The stereo shop did have to put on an engine noise filter near my amp.
Old 04-29-2003, 10:36 AM
  #40
swftiii
swftiii's Avatar
Post
With the new head unit in mine and the amp under the passenger seat there was no pop, but I didn't remount the amp in the trunk so I'm not sure about that location and impact.
I had reached the end of my rope and had decided that if the Alpine installation didn't fix it, it was going to stay as is. The popping didn't occur every time and was only very brief.
Good luck and let me know what you do and if you resolve it.
Skip
Quick Reply: HIDs pop when turned on...help please!
