Looking for feedback on those that use Motul oil
My guy used Brad Penn in my car.
"LSPI is an abnormal combustion event in which the fuel-air mixture ignites before intended, causing excessive pressures inside the engine's cylinders." Wasn't this called engine knock at one time?
Let me understand, direct-injected engines time the deposition of fuel in the cylinders directly allowing for an engine with greater timing advance and compression, making more power but now proving to not be immune to fuel preignition, go figure,
Andy
With no ability to wash the intake valves like our PFI 993's. Unless the vehicle has combined both DI and PFI to alleviate the DI issue which some manufactures have gone to. The F150 with 2.7 TT now has such.
2018 pdf - https://www.rx8club.com/attachments/series-i-tech-garage-22/283772d1529533591-oil-what-brand-you-using-mobil-1-oil-product-specs-guide.pdf
2022 pdf - https://www.mobil.com/lubricants/-/m...--may-2022.pdf
BTW - Mobil 1 Product Guides from 2009 and 2013 also show the same amounts of Zinc and Phosphorus as the 2022 Guide Shows (at least for 15W-50).
For the heck of it, I went to the Mobil 1 site and use their "Find the right oil for your vehicle" search function. The top matches (based on a 1995 911, over 75,000 miles) are the Full Synthetic High Mileage, Extended Performance, and ESP 5W-30 oils.
Each of these has a nominal zinc level of 900 ppm.
I use this because it's what the engine builder told me to. I've always avoided this debate and listened to the guy who assembled the thing. Take that for what you will.
Motul 100273 4100 Power 15W-50 Semi-Synthetic Motor Oil
Motul user here, but 993 now gone after 17 wonderful years. My 80-year-old knees curtailed my driving, but I still come back here to see what is happening with my huge favorite of 7 Porsches in 50 years of ownership (and to check out Gbos1's avatars).
The following 2 users liked this post by BobbyT:
rlme36 (02-17-2023),
Twilightblue28A (02-26-2023)
Considering a Motul for my wife's new GR86 but I use Joe Gibbs Racing Driven GP-1 after talking at length to the LN Engineering guys. Change twice a year, only drive the car about 2x per week.
