Blaupunkt Frankfurt
Blaupunkt Frankfurt
Hey everyone,
Just ordered a new headunit, Blaupunkt Frankfurt, for the 993. Its the new version of the blaupunkt Bremen. Anyone have this unit in their 993 yet? If so, thoughts?
Thanks in advance!
Derek
Thanks in advance!
Derek
M. Schneider (10-16-2023)
Good timing, I just installed mine over Easter weekend! So, early days for me. Here it is installed:
The Frankfurt RCM 82 DAB is a slight update to the Bremen SQR 46 DAB, for which there is a long running thread here: https://rennlist.com/forums/993-foru...qr-46-dab.html
Key differences per my understanding:
As I say, early days, so eager to see how others get on with theirs. Do post back with your thoughts once installed .
- The Frankfurt introduces later Bluetooth version support (I am not sure which version, but it's 5.x) over the Bremen
- The Frankfurt is able to to play FLAC natively, the Bremen cannot
- The Bremen supports the older 30-pin Apple devices, the Frankfurt does not
- They are pretty much the same apart from aesthetics!
- Feature rich, and does everything you'd expect from a modern single-DIN unit
- Bluetooth works great, my typical use-case is Google Maps + TuneIn playing on the iPhone, and these play, via BT, through the headunit and car speakers just fine
- DAB doesn't interest me so much so didn't bother with the DAB aerial for now.
- Whilst the unit is supplied with a dedicated mic, there is also a mic on the front of the headunit itself (see above/left of the volume ****) and is supposed to be good enough for conversations. I am yet to test this and will decide on plugging in the mic after seeing how it goes.
- The biggest let down (so far) is build quality. FYI I have had a Becker Grand Prix for the last 9 years. The Frankfurt is definitely a 'Made in China' product, whereas the Becker felt like a 'Made in Germany' product. The Frankfurt's buttons feel really cheap, hollow, 'plastiky' and clicky. The press of a button on the Becker vs Blaupunkt is what I think closing a door on a Porsche 993 and a VW Up would compare like - - the Becker just oozes quality from a 'tactility' perspective.
The following 3 users liked this post by ch3tman:
Installed one last week. I had to open a dialogue with Blaupunkt Customer Support as I could not get it to work with my iPod Classic. They were very responsive and, at first, puzzled because all their advertising clearly states iPod support via USB. In the end they found the Frankfurt uses the latest Apple chip which only supports iPod's with a Lightning connector and not the older 30 pin connector. This means any iPod produced before about 2012 will not work and the only ones that are compatible are the iPod Touch 5th, 6th and 7th Gen. No big deal other than a shame to bin a still functioning device. I bought a s/h 5th Gen 32Gb off ebay for $40 and that works seamlessly. Everything else works nicely and the sound is very good; the latest chips support FLAC music files and Bluetooth 5 LE. Like Chet I did not bother with the remote mic or fitting a DAB antenna. As regards the buttons they seem perfectly acceptable to me given you rarely need to touch them other than the volume control which does not waggle like the Bremen.
One small foible I have yet to get to the bottom of is the rear USB/iPod connector does not provide a charge current when the ignition is off. My previous Alpine head unit did which meant the iPod was always fully charged and ready to play. The radio does allow playback when the ignition is off but it would be good to have the iPod charging whenever I leave the car. I will contact Blaupunkt Customer Support and see what they say.
Please keep us posted on what Blaupunkt Customer Support say Thumbs up.
Mine is standard stereo and was plug'n play. A plug, B plug and antenna connector (you will need the Blaupunkt supplied adapter). Pin 5 for the antenna amplifier is also already there.
Incidentally, the behaviour you seek here, is one I'd like to avoid! I'd rather not have anything draw current from the battery whilst the ignition is off. Granted, most of us keep our cars on trickle charge when at home but if out and about, I'd rather the battery is preserved, regardless how little the draw may be...
UPDATE: Just confirmed both the front and rear USB's only supply power when the head unit is switched on (regardless of the ignition position). If you do switch the head unit on without the ignition it automatically switches off after an hour. Unlike the iPod Classic the Touch has all sorts of connectivity (WiFi, BT, Air Drop, auto update) and a screen that responds to movement so I have just disabled everything to see if that preserves battery life.
I wonder if the front USB can be used to power a phone as it would only need a short lead to the Rennline clock mount?
The following 3 users liked this post by Heuerman:
I’ve had my eye on one of these for a couple months. Looks much better in a 993 than the Bremen…or the Continental I have now…thanks for the pics! Will be upgrading audio when I take it out of winter storage.
I'm not a huge audiophile, so forgive me. But what makes the Frankfurt better than the Continental other than aesthetics? I like that the Continental connects to my phone every time, sounds fine, and is decent for calls.
asj262 (04-14-2023)
Had another play with the Frankfurt and found the front USB has enough power to charge the phone as well as allowing calls or music to be played. Used with the Rennline magnetic holder it makes for a nice clean pairing with a short cable:
You guys are hell on my wallet lol. That Blaupunkt Frankfurt looks Fantastic in the 993, I just can't bring myself to replace my Blaupunkt Toronto which works perfectly fine now that I disassembled the face and hit the volume know with deoxit, damn lol.
