Pa Euros: 993 Headlight upgrade
Premium Dealer
Hello Rennlist!
Pa Euros is a small enthusiast based European specific sales and service center located in Exton, Pa. We focus on all Euro makes and models but we have a strong focus on late model Porsches (yes, the ones with water in them). Occasionally we get to see and service some 930, 964 and 993 911's.
Recently a customer of ours asked us if we could update the lights on his Speed Yellow 993 C4. His request was he wanted to keep the oem Porsche look and stay away from the real obvious retro kits on the market used by various other Porsche builders. We thought it turned out great and wanted to share. If anyone has any questions comments or feedback please comment below.
If any one is in or around the greater Philadelphia area and would like this done to their 993. Please PM me!
Enjoy!
Parts Used listed below
The Retrofit Source
H410
Splitter: H1M > H1F / 9006F
H20
HD Relay: H1/H3
MM.N.013
H1: XB 5000K HID Bulbs (Pair)
BL11
35w / AMP: Morimoto XB Ballast
RQ160
RQ Hardware: Porsche 993 (Mini H1 7.0)
PR011
Bi-Xenon: Morimoto Mini H1 8.0 (LHD)
Enjoy!
The Retrofit Source
H410
H20
HD Relay: H1/H3
MM.N.013
BL11
RQ160
PR011
rtl5009 (07-25-2023)
Nice mod. I pioneered this system about 10 years ago, way before TRS offered a kit.
I obviously installed early version Morimotos but the good thing is that they can handle 55w burners. Big and noticeable difference to 35w.
If I'd do it again today, I would use their led units, brights with GTR led.
I think your customer will be happy.
I have these Morimotos, with Tore's HID bulb system, and you don't need the 'full beam' bulbs to do anything - seriously - the unrestricted HID single bulb light is that good.
https://rennlist.com/forums/993-foru...pgrades-3.html
see this thread - a photo of what the driver sees with dipped and full beam in the dark is in post #30 or #31
The Morimoto Projector is a "BiXenon" system with a high and low beam built into it using a solenoid operated shutter to open up the optics for high beam. To operate the projector's shutter a jumper connection to the stock high beam circuit is required to make the high beam function work.
The stock Projector for low beam does not have a movable shutter and is thus a low beam light only.
So, theoretically the original high beam of the 993 unit is redundant to a Morimoto Projector. .
I have the Morimoto projectors with Tore's HID kit as well as his LED high beam kit and have thought about wiring the system so the LED high beam is operated by a separate switch since it is so bright and using the Morimoto Projector's high beam for routine high beam use.
This is great! One question, what is the effect on oncoming drivers? We don't need to blind the opposing traffic, just thinking out loud about some of the systems I have seen lately coming from the other direction.
The beautiful yellow car does not have a build sheet.
the Retrofit source used to market the 993 retrofit kit…new Morimoto bi-xenon’s, with specific hardware to bolt, and plug and play in our cars. Add in the high beam harness, with Tore B’s HIDs in the bi-xenon location, and an LED in the Oem location…that additional harness gives you essentially two high beams.
I did this mod a few years ago, combined with Tore’s full exterior LED kit with euro fog locations added to the brake lights. Stunning transformation.
OsbourneRuddock (07-26-2023)
I did the Morimoto projectors a few years ago and was only able to set up the headlights so that either the low or high beams were aimed correctly, but not both. I posted a thread on it. There is no adjustability in the stock housing. This was back in late 2018 -- anyone know if there is an updated design? It was very frustrating. I am not a novice working on cars and there was absolutely no way to create a normal high and low beam situation with the Morimoto projectors. It was one or the other.
I fitted the Morimoto projectors in March 2018, version 7.0 as above, so they must pre-date yours. I don't understand what your issue is? The projectors, with solenoid-operated cut-off, are angled correctly for low-beam. The high beam doesn't have an 'aim', it is simply the low-beam with the metal cut-off moved out of the way?
Magdaddy (07-29-2023)
Hi Christian,
Nice neat install much like how the factory did this.
If an HID Zenon kit used has compact ballasts the entire system including the ballast will fit inside the factory headlight pods.
Tore (Bergvill FX) makes a kit that also includes a nice mounting for the ballast and shorter high-voltage wires specifically tailored for an installation contained in the pods for the 993.
https://www.bergvillfx.com/categorie...kits-and-lamps
Have a great day,
Andy
Have a great day,
Andy
