PCCM Adapter for RCA Amp
I am planning on installing a PCCM radio. Currently my car has a prior owner installed Alpine headunit with a Hertz amp installed under the passenger seat. This is a non-HiFi car.
Looking at the connections on the back of my headunit, the amp is connected via RCA cables.
Is there an adapter for RCA cables like this one with the 6 pin yellow connector? https://www.suncoastparts.com/produc...BLAUPUNKT.html
Pics below of the back of my current headunit (RCA inputs on the right) and the limited options on the back of the PCCM.
I am a DIYer through and through, so I would rather not take it to an audio installation shop.
Think I may have answered my own question. I found this: https://www.ebay.com/itm/12411452000...Bk9SR4zA_IP4Yg
Does anyone know if this is the only option? Any better quality or OEM-like adapter cable out there?
The cable you found looks to be the "solution".
I was thinking about changing out the Alpine head unit with amps fed by RCA cables in my car, and had found this Pelican Parts discussion on the same topic.
https://forums.pelicanparts.com/pors...amplifier.html
