Did US version S/4S also got longer gears?
Yes. US and Canadian cars had the longer geared G50/20 from the start of production on all models. ROW cars were blessed with the shorter/closer geared G50/21 through early calendar year 96 I believe then also switched to the G50/20 for the rest of 993 production.
M. Schneider (01-07-2024)
So if I want shorter geared 993 I need buy RoW until early 96? Did early 4S also got shorter G50/21?
God luck by finding another 993 Gearbox, especially a G50/21.
If you do, be prepared to pay a fortune without knowing the conditions of the box.
If you really want to do something, just re-gear your existing box
The following 2 users liked this post by Holger3.2:
911F1 (01-08-2024),
timothymoffat (01-03-2024)
ROW narrow bodied cars, 2wd and 4wd, had the /21 gearbox until they exhausted supply in the factory, sometime around August 1996
(obviously all 4wd cars had the G64, and the 2wd had the G50)
G50/21; 4th gear @ 6800rpm: 114(ish)mph
5th gear @ 6800rpm: 141(ish)mph
G50/20: 4th gear @ 6800rpm: 138(ish) mph
5th gear @ 6800rpm: 159(ish) mph
Out of interest, which one is better? if any is better
Noodle Jr.
I always wanted a regear but just didn't have the money to throw at it when the trans was out. It would definitely be better suited to my frequent trips into the mountains.
timothymoffat (01-05-2024)
When i searched for a gearbox, the cheapest started by $15K, and that was still a G50/20. I decided to put in a 996/7 GT3 box, nearly completely regeared, and still cheaper!!
But also IMHO, that makes only sense if you convert a tipper...
Noodle Jr.
jepp, over the thumb about $ 1,000 per gear you want to change, but compared with the insane prices for a full gearbox (if you find one), its still comparable 'inexpensive' ...
The reason of the mistake is dual: first from my longest trip so fa (400 miles) and downhill, 4th gear the car didn't go faster (compared to a modern Hybrid I use as well), and secondly, I went to the official Porsche garage to chat with a mechanic and he said I might have the short one.
Sorry again and thanks for the learning !!! THANKS
orangecurry (01-06-2024)
