M033 and Koni SA vs B8’s
Looking at M033 springs. I did Koni Special Actives on my last 993. Any advantage to going with Bilstien B8’s?
If you liked the ride/compliance of the Konis, I’d go with them again. The Bilsteins are a bit more firm IMO. However, the B8s will allow you to adjust ride height at all 4 corners. Konis are only front height adjustable.
Thanks Nam!
I agree- probably in the minority here but regret going with the Koni special actives mostly for that reason. If I had to do it all over I would go with Bilstein, or the yellow Koni Sports which I think are also fully height adjustable.
Onami (02-23-2024)
Thats a no. Koni Sports are also non height adjustable on the rears.
Onami (02-24-2024)
Onami (03-05-2024)
Just for reference I went with the M029 (ROW Standard which is 10mm higher in front, 20mm higher in the rear compared to M033 with apparently the same spring rate) with Koni Actives from Gert and couldn't be happier for a street only car.
Cup 2's: M029 with Koni Actives:
Prior owner installed H&R Lowering Springs; I sold the BBS wheels to fund some maintenance. It looked nice but the combination of those springs, larger wheels and original struts was terrible.
