Sure, I'll take a free FOB....
Basic Sponsor
Last year, I embarked on a project to design a 993-compatible FOB, driven by curiosity and the possibility of improving performance and reliability.
While the circuitry posed minimal challenges, reverse engineering the Porsche encryption scheme proved difficult. So I got sidetracked on a mini encryption research project. After much trial and error and experimentation, I deciphered the encryption and built a single prototype that I tested on my '97. To my delight, the prototype worked out to 60 ft — 2 to 4 times greater than the 3 other FOBs I tested side-by-side. Actual range is going to vary with each 993, but these results suggest users could reasonably expect to get at least twice the range they are currently getting.
The new design operates on a lithium coin cell, a change that eliminates the often-troublesome OE battery terminals. With a shelf life of 10 years and a demonstrated lifespan of over 20,000 uses, most users may never need to replace the battery. The new design also closes a security loophole in the older OE design.
First-article prototypes are ready for testing. I’m seeking a few owners willing to use one for a while and provide feedback. If the results prove promising and the interest is there, production could commence shortly. Thanks to the simplicity of the design and high level of integration, I anticipate being able to offer these at a significantly lower price than OE. Hopefully, this may encourage owners without a backup FOB to get one.
Currently, I have a limited number of prototypes available and seek beta testers who:
- Have a US/Canadian-market Drive Block-equipped 993 with a functional, unmodified immobilizer.
- Regularly drive, preferably on a daily basis.
- Know their 4-digit immobilizer PIN code.
- Are capable of programming FOBs, preferably with prior successful experience.
GJSPIN (03-13-2024)
Interested, but not sure about the 4 digit pin.
I would be interested. I programmed one on my two FOBs, so I have some experience. Does the increased range in anyway increase the probability of someone “hacking” your FOB?
OOPS, used my old account...
Great project Jay. I'.m RoW so can't take part but am looking forward to seeing the results. Nothing worse than walking too far from your car to be able lock it then having to walk back to it. I'm not very cool to start with add in that maneuver and it's totally uncool looking
Basic Sponsor
Thx. My range is probably 20-25'. I guess just spoiled with modern remotes..
Basic Sponsor
Thanks everyone. All the beta test FOBs have been spoken for. Wish I had more to give away! If the testing goes well I should be able to have them available towards end of May. If you’re in the market for a spare, I may kick things off with a group buy.
Just commenting to say this is an exciting potential new part and I'm eagerly awaiting their availability for sale.
Also, thank you for surfacing this fob range repair / mod with the fresh capacitor caps. Just added that to my warm weather to-do list of cheap little projects!
Basic Sponsor
An improved range may also require a capacitor be replaced in the immobilizer.
Loren
Systems Consulting - Automotive Electronics
Specializing in Porsche cars
http://www.systemsc.com/
Loren
Saw several replies asking how to mate the fobs to the car.
Here is a page that covers this:
https://993servicerepair.blogspot.co...ming-made.html
Andy
Andy
Basic Sponsor
Andy
Andy
1. Open door, insert key, and turn key to run mode. Immobilizer light should come on.
2. After about 15 seconds, the light should go off. Turn key off then on (cycle key).
3. After about 15 seconds, the light will start to flash on/off. Cycle the key to enter each
of the four digits. Wait about a second between each digit.
4. If the code is correct, the light will again begin to flash on/off. Depress the button on each remote one at a time.
5. Turn the key off, exit the vehicle, close the door, and test each remote.
6. If step #3 doesn't occur, the ignition switch is most likely bad. The immobilizer then needs to be
programmed externally.
