993 Forum 1995-1998
Sponsored by: DashLynx
Cost to Replace Spark Plug Wires, Rotors, Caps
Old 03-16-2024, 04:55 PM
Mhodor1972
Mhodor1972's Avatar
Default Cost to Replace Spark Plug Wires, Rotors, Caps
I have a 1995 993 carrera 2 coupe and was advised that I need to have my spark plugs, rotors, spark plug wires, and caps replaced.
For those who have performed this work recently, could you let me know what an independent Porsche mechanic would likely charge?
Old 03-16-2024, 05:18 PM
boomboomthump
boomboomthump's Avatar
Minimally, I'd say $1100-1300 dependent on shop rates.
At the best prices, the parts alone are $850... ($550+ for the wires, 12 plugs @ $6/ea, 2 rotors $25/ea, 2 caps @ $80/ea + tax). So I'd factor $900 + shop labor rates for your area.
Old 03-16-2024, 09:38 PM
gbgastowers
gbgastowers's Avatar
Location: Holden Beach and Winston-Salem, North Carolina 82 928 Euro S 5spd MOSS GREEN/CHAMPAGNE-04 996 C4S CONV TIP POLAR SILVER/METROPOL BLUE
I noticed some cracking in mine observed through the rear wheel openings with tires removed. I cleaned the wires with alcohol and brushed liquid electrical tape on the cracks( mostly at the bends in wire). No more misfires noted and a good temporary fix.
GJSPIN (03-18-2024)
Old 03-16-2024, 11:37 PM
P-daddy
P-daddy's Avatar
Last time I got a quote for wires and plugs alone was $1100. That was 2011 when I purchased my first 993. F$&! that! So I followed instructions found on this forum and DIY’d it. Not difficult at all.
Old 03-18-2024, 04:51 PM
Magdaddy
Magdaddy's Avatar
If no history of prior change, also consider replacing the distributor belt. Age, and ozone aren’t nice to that little dizzy belt.
sdm100 (03-19-2024)
Old 03-18-2024, 06:09 PM
IainM
IainM's Avatar
As long as you have the clear plastic tubing connecting dizzy to rear blower ducts (and it’s airtight) then Ozone is not an issue.
25yrs+ of heat soak on the other hand....
Old 03-18-2024, 07:07 PM
mlenox
mlenox's Avatar
my work was bundled with a few other things like a leaking gasket, but it was more than $2k to have everything you listed done.
Old 03-18-2024, 09:42 PM
Magdaddy
Magdaddy's Avatar
wasn’t on early 95 models, if I remember correctly.
Quick Reply: Cost to Replace Spark Plug Wires, Rotors, Caps
