Ignition
Ignition
Hi all.
I just replaced by battery but the car will not start. I turn the key and nothing happens, but the lights come on on the gauges.
PLEASE HELP
Mitch
PLEASE HELP
Mitch
Does it crank? What year? Need more details.
Is your immobilizer in proper working condition? Try locking, then unlocking, then starting. Any change in behavior?
Next step would be making sure your connections at the battery are good.
If it's a manual, can you bump start it?
pp000830 (04-06-2024)
Basic Sponsor
As a test...bypass Starter relay R61 (Terminal 3 to 5).
The easy way to do that in a CAB is to temporarily move the jumper module you have in R21 to R61's slot and try starting.
If the car cranks and starts, it's either the clutch interlock switch or a bad R61. (Leaving R61 bypassed is the easy fix).
If it just cranks but doesn't start - suspicion points to the immobilizer.
The jumper module you should find in R21 slot looks like this:
My '96 993 doesn't have a clutch interlock switch or some previous owner removed it. Not needed and it is a point of failure.
Basic Sponsor
Yeah, it's a 97/98 thing. I bypassed mine - one less thing to worry about..
Andy
Basic Sponsor
Mitch - the pic below shows what you want to do in the fusebox. Your box may not look exactly like this one but In a 98 CAB you should see the jumper module shown in slot R21. Move it over and plug it into R61's slot. That's the starter relay you want to bypass for this test. (R21 powers the roof so will be temporarily disabled). Try starting the car and let us know what happens.
