It finally happened...
...after 10 years of ownership the 993 refused to start!
Today's a beautiful day in these parts and perfect for getting the car out after a winter's slumber. Car just kept cranking and not firing. I couldn't hear the fuel pump priming so I put my spare DME relay in and it fired right up.
I love this car... here it is next to other hard working machines.
The following 5 users liked this post by uniquenamehere:
996scott (04-08-2024),
boomboomthump (04-07-2024),
dimi_108 (Yesterday),
orangecurry (04-07-2024),
SpeedyC2 (04-08-2024)
The nice thing is that because the old DME failed, all the cranking built up some oil pressure after the long winter dormancy before the new DME fired it to life.
Enjoy the driving season!
Glad you got it sorted!
Exact same experience for me when it finally failed. 90 seconds later I was on my way again.
Frequent advice is to re-solder the failed relay circuit board and keep that relay as your new spare. Several DIY posts here in the forum.
Ron
Ron
I did take the old relay apart and all the solder joints all appeared to be okay.
I re-soldered everything anyway and tested on the bench with a 12v power supply and it appears to be working again. I kinda wish I tested it before as well, but oh well...happy to have a spare one again!
Hairline cracks can be hard to see without a scope. The other thing you can do is wiggle the hardware while holding the PCB. Any movement of the pins relative to the board is indicative of broken solder joints.
nicely done,
nicely done,
solid state relay time
