Stalling
Stalling
Car runs beautifully…perfect…but when I come to an intersection and brake..rev drops..stalls…start up and go, all good….next intersection stalls. Does this about four times then after about 10 minutes, simply stops stalling - all good again.
Clearly a little unnerving…particularly if my wife is driving. Any ideas/ theories? It running beautifully today.
Anything to start chasing down?
Goose 993 (04-29-2024)
Have you checked/cleaned the ISV (idle speed valve)? https://rennlist.com/forums/993-forum/1284047-isv.html
pp000830 (04-17-2024)
ISV was the first thing I thought of also.
Can be a PITA to remove but there are good DIY's & tips. it's been 12 years or so but I think I remember spraying the rubber sleeve/grommet that holds the ISV with PB Blaster and letting it soak in overnight to help.
coreseller (04-30-2024)
Hi Overdraft,
The page below discusses root causes of idle and poor running issues:
https://993servicerepair.blogspot.co...r-robbing.html
Andy
Andy
I'll "eat my hat" if it's not the ISV. When you yank it out I'm sure you'll find it's all gummed up with oil residue. Get a can or two of carb or brake cleaner, remove the ISV and start spraying.
When you shake/rotate the ISV like a you should hear the valve moving around freely, like this:
baceto (04-29-2024)
When you shake/rotate the ISV like a rattle drum you should hear the valve moving around freely, like this:
https://vimeo.com/936635095
pp000830 (04-30-2024)
Rennlist success stories ftw!
The following 3 users liked this post by Goose 993:
