993 Forum 1995-1998
Is this a DIY item???
Old 07-11-2005, 10:52 AM
Don Magee
Don Magee's Avatar
Default Is this a DIY item???
During a resent DE event, I noticed the rubber boot connection between the heater blower intake and the main engine fan is split open and cracked.( I apologize for the vague desciption. I would post a photo, but I do not have one and have no idea how to upload a photo.) The rubber tube piece appears to just slip onto the heater blower side, similar to the way the clutch vent tube connects to the air filter cover. But, the connection to the engine fan shroud looks like it could be a PITA.
My questions are:
A. Does my word picture make any sense?
B. Is this a PITA to replace, or could a moron with a wrench(me) replace it?
As always, thanks for the help.
Old 07-11-2005, 11:05 AM
ppressle
ppressle's Avatar
Very easy to replace. The tube side kind of slips on, with a little ridge it fits over. The engine side has a couple of bolts, that you can just loosen rather than remove to free the part.
Old 07-11-2005, 11:30 AM
Rick Lee
Rick Lee's Avatar
Yes, this is an under 5 min. job in a rainy parking lot.
Old 07-11-2005, 11:40 AM
Don Magee
Don Magee's Avatar
Cool. Thanks, guys.
Old 07-11-2005, 01:45 PM
nile13
nile13's Avatar
I need to replace mine too. Does anyone have the part number and price?
Old 07-11-2005, 04:02 PM
kkim
kkim's Avatar
Mike,
check this thread for the part #... and to see if we're talking about the same part.
https://rennlist.com/forums/showthre...highlight=hole
Old 07-11-2005, 04:14 PM
Rick Lee
Rick Lee's Avatar
Don's first, since he posted the question, but come to think of it, my old one is available for the cost of shipping. It's in perfect condition and I only replaced it with the 964 version, which is required to mate with the RS heater bypass tube.
Old 07-11-2005, 04:32 PM
nile13
nile13's Avatar
Thanks, Kelly!
I looked it up at Pelican and it gave me a 964 part number. Good thing the thread you've referenced contains the 993 number (strangely, all other digits are the same).
Old 07-11-2005, 04:34 PM
nile13
nile13's Avatar
Rick, if Don doesn't take it, I will. Sent you an email.
Thanks!
Old 07-11-2005, 04:44 PM
Dudley
Dudley's Avatar
Mike,
When you stop by tonight, remind me to show you my new rubber boot. It is the second one I have ordered. The early build MY95 use the 964 part number, the neck is a bit shorter than the 993 part number which you find in late build MY95 and beyond.
If you order the part for a MY95, PET will give you the 964 number. If you have a MY95, it is worth the time to take it off and check the part number on the inside of the hood - then you are sure top get the right one. The part, including shipping from Sunset, cost $32.98.
Old 07-11-2005, 05:08 PM
nile13
nile13's Avatar
Dave, my car is an April 94 build. So it sounds like I will need a 964 number.
Quick Reply: Is this a DIY item???
