Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat
Go Back   Rennlist Discussion Forums > Air/Oil Cooled Technical Discussion Areas > 993 Forum
Sign in using an external account
Register Forgot Password?
Thread Tools Search this Thread
Old 07-16-2005, 09:56 AM   #1
Robert Linton
Robert Linton's Avatar
Default Another Potential Weight Saving. Can Anyone Answer The Question?
Is the frame around the air conditioning condenser steel?
Robert Linton is offline   Reply With Quote
Old 07-16-2005, 12:57 PM   #2
3.2 Targa
3.2 Targa's Avatar
Hi Robert,
You 've got a cool project going.
The condenser bracket/frame is steel. I just verified with a magnet since mine is accessible due to ballast resistor replacement.
The Oil cooler frame is Alu.
HTH,
Scott
Scott C.
3.2 Targa is offline   Reply With Quote
Old 07-16-2005, 01:04 PM   #3
Robert Linton
Thank you. That's what I thought but was not sure. As such, it could be made out of aluminum or, if greater strength and durability are considerations, possibly heavier (but about 35% -40% lighter than steel) titanium.
Old 07-16-2005, 01:34 PM   #4
3.2 Targa
3.2 Targa's Avatar
Great..... Don't be singy with pictures!
Scott C.
Old 07-16-2005, 02:10 PM   #5
Robert Linton
Will post pictures of the new one.
P.S. Pictures of the lightweight oil coolers -- three weigh less the original one.
Old 07-16-2005, 02:12 PM   #6
24FPS
24FPS's Avatar
expose your film & drive
officialauteurforhey wait for meracing
fear eats the soul.
rlm 031107-4606 | rlm 070728-6927
ich
was ich
24FPS is offline   Reply With Quote
Old 07-16-2005, 05:07 PM   #7
3.2 Targa
3.2 Targa's Avatar
Robert,
I've been giving the bracket more thought.
I would recommend using Alu since the ballast resistor mounts to the bracket.
Ti. may be too thermally resistive and cause localized heating on the resistor and shortening its life.
Al may be more effective moving heat away from the resistor.
I haven't checked thermal properties of Ti lately so I may be wrong....... Just something to consider.
BTW, cool heat exchangers.
Scott C.
Old 07-17-2005, 12:18 AM   #8
WarpMan
WarpMan's Avatar
Robert,
I would concur with the assessment by Scott C. Titanium is essentially a thermal isolator compared with aluminum (coefficient of conduction is about an order of magnitude less). If the cooler were made of aluminum, making the bracket titanium might introduce corrosion issues (titanium and aluminum are pretty far apart on the galvanic table).
Yuji
"Any excuse for a road trip"
1998 993 Carrera S, Vesuvio Metallic/Black
WarpMan is offline   Reply With Quote
Old 07-17-2005, 12:38 PM   #9
Cy
User
Cy's Avatar
Scott,
The ballast resistors for both the oil cooler and AC condensor do mount to the brackets. However, as others here have done they can be moved to alternate locations that still provide for heat sink, air flow, and easier access for future replacement.
Regards,
Cy is offline   Reply With Quote
Old 10-27-2005, 08:53 AM   #10
Robert Linton
The steel frame weighed approximately 1.62 kg. The aluminum version weighs approximately .44 kg. Savings of approximately 2.6 lbs.
Old 10-27-2005, 12:11 PM   #11
TomF
TomF's Avatar
Thanks for the update. Can you post more pics of your current projects or direct us to a link?
TomF is offline   Reply With Quote
Old 10-27-2005, 04:45 PM   #12
zwoobah
User
Sounds like a cool project, but if you're trying to reduce weight, why not just scrap the AC entirely? Are you focusing on minimizing the weight of a full-featured street car as an engineering exercise?
zwoobah is offline   Reply With Quote
Old 10-27-2005, 07:35 PM   #13
Robert Linton
The modern 911R -- 2200 lbs., 425 normally aspirated horsepower, full interior, air conditioning, airbags, stereo, etc.
Old 10-27-2005, 08:18 PM   #14
Joe S.
Joe S.'s Avatar
Quote:
Can you share any details on this?
Joe
Joe S. is offline   Reply With Quote
Old 10-27-2005, 10:52 PM   #15
zwoobah
User
Sounds like an incredible engineering exercise, it's always a pleasure to see the absolute best that can be done in any automotive buildup.
A couple of the more interesting weight-saving parts I remember from recent automotive history are:
-The lightweight head unit that Kenwood developed specifically for the McLaren F1
-The hollow carpet fibers Toyota utilized in the twin-turbo Supra
Best of luck with the project, keep us updated
Tags
headunit, lightweight
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
Copyright © 1998 - 2007 Rennlist.com
Advertise on Rennlist - Terms of Service - Privacy Policy - Jobs
Emails & Contact Details
