993 Forum 1995-1998
Sponsored by: DashLynx
Cigarette lighter won't stay pushed in. FIXED!!!!!!!! read on
Old 10-27-2005, 11:42 PM
ca993twin
ca993twin's Avatar
Question Cigarette lighter won't stay pushed in. FIXED!!!!!!!! read on
First of all, I don't smoke and will not allow any smoking in my car. But in the interest of trying to get Rufus PERFECT, I noticed that the cigarette lighter won't stay pushed in while it heats up. I just bought (and received) a new lighter from a great Rennlister, and it does the same thing. There is power to the lighter (it will heat-up if I hold it in). This is something I can live with, but now its starting to bug me. Anybody ever fix something like this? I assume its something mechanical in the socket.
Old 10-27-2005, 11:59 PM
epj993
epj993's Avatar
Hey, I've got the same problem. Not really bothered with it so far but hope someone has an answer.
Old 10-28-2005, 01:56 AM
Vince 97' 993 TT
Vince 97' 993 TT's Avatar
Unhappy
I too have the same problem....
Old 10-28-2005, 02:07 AM
ca993twin
ca993twin's Avatar
Vince,
Sorry, but you can't have the same problem... it only happens to Arena Red cars. Something to do with the magnetic flux field and the position of the stars.
Old 10-28-2005, 02:12 AM
Vince 97' 993 TT
Wink
Originally Posted by ca993twin
Vince,
LOL...I wish that were true
Old 10-28-2005, 01:24 PM
Chuck W.
Chuck W.'s Avatar
I have the same problem with my Glacier White car. But it is understandable because most of the factories efforts were placed on putting the strongest engine in the white cars.
Old 10-28-2005, 03:01 PM
Racer944
Racer944's Avatar
Hmmmm.... I though this was the way the system was designed. My 944's did the same thing. Maybe I made an incorrect assumption though...
Eric
Old 10-28-2005, 03:06 PM
ca993twin
ca993twin's Avatar
Eric,
I hope you're wrong. I wouldn't want to think that Porsche would stand alone in the world of cigarette lighters and require you to hold the damn thing in while attempting to drink hot coffee, talk on the cell phone, and perhaps even drive at the same time. No way.
Old 10-28-2005, 04:20 PM
Vince 97' 993 TT
Smile
Steve, I got a great idea.... Just roll up Rufus to about a buck fifty, and slam on the breaks for a good 30 seconds... and the G-Force should allow the cigarette lighter to stay in place till it gets nice and hot.... if not, just have your smoking friend stick his or her head to the rotors, and this too should be hot enough....
Old 10-28-2005, 09:15 PM
Kigiin
Kigiin's Avatar
Same problem too. Anybody check the manual? I would check myself, but that would require getting off the couch.
Rob
Old 10-28-2005, 09:28 PM
Ray Calvo
Passed On
Ray Calvo's Avatar
What part of the lighter did you replace? The heating element (part you yank out of the socket and hold against the cigarette) or the whole unit? If just the heating element, replace the whole danged thing, dummy! If you did replace the whole thing, and both the socket and heating element came together, then you likely got a bad lighter - get one from a dealer, not a "great Rennlister" who probably sold it because it didn't work for him. From your description, you replaced only the heating element, then started whining.
One thought: I have had some trouble with non-Porsche heating elements not working properly. They do what you are experiencing - won't latch in when you press them in. Make sure it's a Porsche lighter.
Old 10-28-2005, 09:46 PM
STLPCA
Addict & Guru
STLPCA's Avatar
Steve
There's a 2 prong spring at the base of the socket that catches the lip on the plug-in heating element. When the element heats up it heats the spring which expands & releases. No doubt your spring has been expanded from use - probably plug-in adapters. You can either replace the socket or try to tighten it up slightly (w/the power off) until it catches.
Old 10-28-2005, 10:52 PM
AOW162435
Seared
AOW162435's Avatar
Thanks Ray. I was the "great Rennlister" who sold the lighter insert to Steve. It was brand new and was an extra that came with my car.
The socket in my car does work. Thanks for your cynicism.
Andreas
Old 10-29-2005, 12:37 AM
ca993twin
ca993twin's Avatar
Vince,
I'm going to test out your technique, but I don't think 150 gives enough braking time. Gonna try 200.
Dan,
Thanks for the freat technical advice... as usual. For me, since there is no smoking in my car(s), its simply not worth the bother to replace the socket. The repair??? Maybe.
Ray,
You really are too cynical.
Andreas,
Thanks again, and thanks for posting the picrure so it is clear... its a BRAND NEW Porsche lighter element.
Old 10-29-2005, 02:06 AM
Brett - 1996 C4
Brett - 1996 C4's Avatar
Thumbs down
I pitched my lighter, but I've noticed that neither the rechargable flashlight nor the battery trickle charger that I plug in there fits very tightly. It doesn't take much of a bump to dislodge them. Thanks, Porsche!
Quick Reply: Cigarette lighter won't stay pushed in. FIXED!!!!!!!! read on
