Aaagh, I hate this cabriolet top!
Once properly adjusted, my top has work flawlessly. It's been nearly three years with no problems - the great weather here results in the top being actuated probably 200+ days a year.
The difficult aspect of the top is finding a person with the expertise to properly adjust them. They are complicated, but once set up properly, they are golden!
:cheeers:
:cheeers:
Originally Posted by fbfisher
A new top can be had installed in Los Angeles for $1,000.
I need a new top badly. Even before that I need a new cable for teh passenger's side transmission, as mine has shrunk (the transmission itself seem to work). Of course they don't sell cables separately. Arrrgh.
Originally Posted by Chuck W.
I disconnected the control arms on my top and now operate it manually. I got so tired of the transmissions, cables and adjustments. The only thing I have to be concerned with now are the top motors that connect the top to the car.
I've converted both my BMW E30s to manual top operation as well as having teh manual top on my Miata, but, boy, is 993 top a heavy sucker! Plus this stress issue is a great concern.
Originally Posted by nile13
I keep hearing of these great prices out West, but here is Boston I have not found anything for under $1700, and it appears that $2K is more realistic.
Suggestion #2: Drive your car out here, hang for a few days with us So Cal folks, and then drive your car home.
Suggestion #1: make a few calls to independent shops and find out who they sublet the top work to. Enough calls and you'll find "the guy" who knows these tops inside and out. Then go direct to that person. The guy here works out of his garage at home. He charges us what he charges the other shops. they then charge "retail".
I also had no problems, then had the top recall done, and shortly after the latching electronics worked fine but then the top started retracting unevenly and eventually the motors blew and it stopped altogether. I'm not sure it had anything to do with the recall as the recall (I think) only involved replacing the latching motor. It's so much easier to just use the electronics for unlatching the top and loosen the bolts in the rear to close and open it as a manual. The only trick is your ! light comes on because the car thinks the top is improperly open, but all you have to do is turn it off on the center console. To me it's not worth the $ to fix a minor, occasionally used, problem, IMHO.
You guys had me truly worried, as I've been irresponsible. Top has been down for months, haven't driven her due to salt on the roads, etc.. Some days where we didn't get up to freezing included. Today was in the 50's. Started her up, ran it long enough to ensure the top was warm, then put it up. All is well! Undoubtedly, the best Christmas gift I'll see this year.
wish i had read this thread yesterday i split my rear window in half this AM. 30 degree weather or so some frost in the bay area, CA... what was the concensus.. can the window be replaced or is it the whole top??? someplace i saw a thread on a zippered in rear window.,. that would be good or better yet some aftermarket rear window made of glass.,,
if it doesn't exist we should make one - id buy it.
First, that sucks.
Second, no, a rigid glass window will not work. Our windows bend during folding.
Third, you can replace the window itself, however it might take some extra care. The window is zipped in, but there is adhesive on and near the zipper, which needs to be removed (at least partially).
I've uploaded the 6 pages of the Shop Manual for your and your installer's reference. I had to break it up into 3 files to get it to upload.
Good luck.
Good luck.
This is what I do now as well. But... I have a nasty feeling that with manual operation the top actually goes down further than it does when arms and cables are attached. Causing extra stress in the line in canvas just under the window. Mine eventually ripped there (not a big loss, top was totally shot well before that), but it concerns me greatly.
The transmissions and cables and adjustments are not worth fighting with not to mention the cost... go manual.
Is it the labor or the cost of the top that's expensive? They might just be marking up the top and that's what puts the cost at near $2k. You may want to ask them how much they'll charge for the install only.
Harry - you need to find another thread. This ones for people that want t complain about their Cab tops and answer questions but have no intention of swtiching to anything else.
RE: IntheAir's post thanks again. I just got off the phone with john at Bascom Trim in CA. he said that they do now have a glass window for the 993 Cab top - said it is about 30% smaller than the regular plastic window and he quoted me a price. Anyway if i can get a picture of what one looks like i post it here.
