993 Forum 1995-1998
Jack plate for 993
Old 01-07-2006, 01:11 PM
Caveman
Caveman's Avatar
Question Jack plate for 993
Hi Everybody,
Does anyone know where I can buy a jack plate tool to use with a two tonne scissor jack in the UK? What do you use to avoid damaging your bodywork?
Thanks and regards,
David
Old 01-07-2006, 02:11 PM
Don Plumley
Don Plumley's Avatar
I use a hockey puck with a 1/2" cap screw. A plain hockey puck works well too. Not an original idea, heard about it here first. I'm running out the door, will snap a pic later today...
Old 01-07-2006, 02:41 PM
epj993
epj993's Avatar
You can also use a door **** hole saw to cut a circular blank out of some 4/4 or 5/4 hardwood. Cheap and easy...
Old 01-07-2006, 04:14 PM
Caveman
Caveman's Avatar
Sorry to be a bit thick but how does a hockey puck sized pad help as from memory this would be too big to sit into the jacking point? Am I missing something?
Cheers,
David
Old 01-07-2006, 04:22 PM
kkim
kkim's Avatar
David, where exactly are you trying to lift from and what type of jack are you using? Pictures might help us to answer your question.
Old 01-07-2006, 04:32 PM
Caveman
Caveman's Avatar
Hi Kelly,
I'm mainly interested in just lifting the back up a bit if I need to change my mufflers so I assume I can jack up the car using the normal jacking points but obviously one of those look to be quite small compared to the "plate" on a hydraulic car jack. I seem to remember when I had my old 911 that you could buy plates that fit into the jacking point and onto the car jack so that you didn't damage the bodywork when you were using it. What do you guys do?
Cheers,
David
Old 01-07-2006, 04:53 PM
kkim
kkim's Avatar
David,
Have you seen this on Pcar? http://p-car.com/diy/jack/
When I work on the back of the car, I lift from the engine as shown in the DIY. I always put the car back on jack stands under the rear side jacking points. You will have to remove your engine cover, though, to be able to lift from the engine. If you feel nervous about lifting from the engine, autometrics makes an engine jacking pad that you bolt to the engine so you have a nice solid area to lift from...
http://p-car.com/diy/jacktowpoint/
If I lift from the side, I use one of these at the rear side jacking point then put a jack stand under the front lifting point. Others have used a hockey puck between the jack lift surface and the lift points to prevent metal to metal contact.
HTH...
Old 01-07-2006, 05:38 PM
Nickels
Nickels's Avatar
Caveman,
The hockey puck fits inside the "cone" of your floor jack. Cost is about $1.50. Good Luck
Old 01-07-2006, 06:20 PM
chris walrod
Guru
Rennlist Small
Business Sponsor
chris walrod's Avatar
This is what I use on my floor jack. Works great and provides good grip on whatever I am jacking on..
Old 01-07-2006, 06:45 PM
Mike J
Mike J's Avatar
Here is what I use...of course home made...
A closer picture...
These hold the jack stands locked to the car and work great.
I also did a variation for the jack itself....got a little more fancy..
Old 01-07-2006, 07:13 PM
John95cab
John95cab's Avatar
Those are fancy. I just use a piece of plywood
Old 01-07-2006, 07:28 PM
Capital
Capital's Avatar
The 993 column in the Porsche Club of Great Britain, Porsche Post (Jan 06) describes something that seems to match what you are looking for. Column was written by Ken Coad. You might want to email him 993@porscheclubgb.com.
Old 01-07-2006, 07:29 PM
Caveman
Caveman's Avatar
Thanks guys! I think I get the idea. I'll see what I can knock up.
Cheers,
David
Old 01-07-2006, 10:33 PM
Dudley
Dudley's Avatar
Here is another option. Aluminum block.
Old 01-07-2006, 11:48 PM
Mike J
Mike J's Avatar
The idea of both the tops of the jackstands and the top for the jack is to have a positive lock from the car to the jackstand. I use plywood to take the engine out for instance but if I go underneath the car I want both my postive lock jackstands on the car as well as an extra set of backups (or jacks) just in case. I don't want to try benchpressing my 993. If I am in a rush I use a thick rubber pad (like the ones found in playgrounds) which is sticky and also tends not to slip.
Cheers,
Mike
Quick Reply: Jack plate for 993
