Help with Fan Belt warning light
For the last two days, my fan belt warning light has come on inside the clock housing. I replaced the fan belts last summer. After the light came on, I pulled over and checked the belts. All seemed okay, and the tension was sufficient to keep the belts rotating. Anything else I should be checking?
Thanks.
Michael
Thanks.
Michael
What they said. It is the belt sensor, which is there to tell you when the belts take leave of the car. They do fail, so check it out. It has no tensioning purpose, so won't hurt anything to run without it until you get a new one if needed.
It's super easy to change (well, if you can get a hex socket in there). I "fixed" mine previously, as it was indicating intermittent belt failure, by spraying some contact cleaner in the micro-switch inside the unit, but it failed again. I just got a new one (arrived yesterday) from Sunset (http://www.sunsetimports.com), who had by far the best price. I'm gonna put it in this weekend and say goodbye to periodic heart attacks while driving.
I don't see the point in keeping the fanbelt sensor. If the fan belt breaks and you don't notice it on your own, you shouldn't be driving a 911 Loud noise of belt whipping against engine compartment, accompanied by sudden rise in engine temperature... gee, what could that be!
That said, they're easy to replace.
I don't have one, and haven't for several years. I got tired after two failed and sounded like an ex-wife screaching while I was driving the car at the track. Who needs THAT! I replace my belts regularly, and when I have seen them go on other cars they often leave in pairs or so, I guess they like company? You will then get lots of input about them being gone if you are familiar with yoiur dash and look at it regularly. Mine failed so regularly i began to wonder if they would really work if the belt broke anyway. BTW, no belt failures in many years with frequent replacement.
But that is a decision each should make.
Bull:
I like your approach. Given the heat back there, I will just put the belts on a two year replacement cycle. I have had the alternator beltbreak last summer, coming back from Las Vegas. I was about 15 miles outside of Boron, California. Boron has a nice, tidy little motel, and a not-half-bad Mexican restaurant. (ask me how I know). They also have a pretty decent mechanic who actually had a replacement belt.
Anyway, thanks for all the responses.
Michael
Michael
TIA
Best Way to Tap into 12V? Want to hardwire Radar Detector
Usually, I would whip out my shop manual and figure out how to get into the dash and figure out a good switched wire to tap into for my radar detector installation, but alas, there doesn't seem to be such a manual. Any of you folks opened up the dash? I could use some instruction.
Originally Posted by TRINITONY
Anyone have DIY for this?
TIA
TIA
