303 aerospace "cleaner"
After reading all the blurbs, both here and elsewhere, about how great "303 aerospace - *" is ...I splashed out and got a gallon each of 'cleaner' and 'protectant'.
This Friday, evening, after work ...I made my first attempt at cleaning the engine.
Boyz-o-boyz-o-boyz. I'm impressed. I used a 20-to-1 dilution to clean the car with a sponge and used the remainder (in my bucket) to clean/de-grease/de-skankify the engine with a nylon scrubbing brush. This was my FIRST attempt at cleaning the engine - so I definitely missed a multitude of nooks-n-crannies - and will probably have to do it again -- probably twice more -- just to get it REALLY spik-n-span -- BUTTTTTTT -- the difference -- after I'd hosed everything down -- was VERY noticeable. The GREAT thing about this stuff is that it's NOT a solvent (like carbon-tetrachloride or acetone or xylene) nor is it caustic. It seems to clean the ick off rubber as easily as it brings metals back to shiney-life.
I think most of us have "shy'd away" from cleaning the engine coz it seems to be too much of a big deal -- or we think we're gonna mess some of the electrics up -- but after using this 303-CLEANER -- I'm a believer.
After I've totally deskanified the engine area I'll tackle the trunk. Then after the trunk -- off come the wheels so I can so the INSIDES of the wheels and the general 'undercarriage area'.
Then I'll "re-do" all those areas with the 303-'protectant'.
Well, the whole weekend is shot here in the NY area ...what with this weather system ...so I gots nuffin' else to do!
Latah,
G.
P.S. Oh yeah, a gallon of EACH ....approx $50 on ...ebay!
Latah,
G.
FYI. They're running a special at autogeek. http://www.autogeek.net/303aecl.html
No affiliation blah blah blah.
Seared
Sometimes I think it would be easier to construct a 1,000 gallon holding tank, fill it with 303, and then simply drive the 993 through it every so often.
I use the stuff everywhere.
Andreas
Andreas
I also use the 303 protectant for all vinyl and textured plastic surfaces. It seems to work very well, doesn't attract too much dust, and isn't nearly as shiny as Armor All or some of the others.
I like Plexus for the shiny plastic and CF bits.
G.
