Public-domain OBD1 PCB board - ORDER HERE
3/3/2007 - I'm leaving this thread because of all the information it contains, but I've removed the Round 1 group buy details. The Round 2 group buy thread is here:
https://rennlist.com/forums/993-forum/334514-obdi-circuit-board-group-buy-round-2-a.html
-Colin
The circuit was designed by Ray (raycm) and it interfaces via computer serial port to scanning software made by Doug (dougb). I did the PCB layout, again with help from Ray.
Details
Details on what this is and how it works can be found here:
Ray's 1995
OBD 1 Diag Tool thread
Laurence's Diag Interface and Software thread
Ray's DIY 1995 OBD 1 scantool thread (Edit - added 8/31/06)
This board works for OBD1-equipped 993s, and 964s with small modifications which can be found in the 964 thread. You can reset codes and read values from the DME, Alarm, Brake system, etc. There is obviously no warranty of any kind, and no liability will be assumed by any participants if you damage your car, computer, or self. However, there are assembled circuits working on both 964s and 993s (including mine) right now.
What you will get
One envelope sent via USPS, containing one BARE printed circuit board. Components are not included.
Board specs:
-Copper traces are 0.025"
-All traces are on the top side
-There is copper lettering indicating part numbers, resistor values, transistor types, etc.
-There is no silkscreen layer
-All holes are plated through, making it easy to solder component leads to either the top or the bottom of the board
-This board should be easy to assemble if you have some previous soldering experience. Components are not spaced particularly closely. Plan on around 2-4 hours of soldering and assembly depending on your experience level.
Price
Price is $26 per board, including shipping to your address in the 48 states only. You will need to obtain the components in the BOM (Bill of Materials, below) and also DougB's diagnostic software.
BOM
C1 0.1uF 25 Volt (such as VishayA104K15X7RF5TAA or K104Z15Y5VE5TL2)
C2 100uF (such as Vishay515D107M025AA6A)
D1 1N4148 Diode
D2 1N4148 Diode
D3 1N4148 Diode
J1 DB9 FEMALE
Q1 2N3904 NPN Transistor
Q2 2N3904 NPN Transistor
Q3 2N3904 NPN Transistor
Q4 2N3906 PNP Transistor
R1 2.2K Resistor 1/4W
R2 2.2K Resistor 1/4W
R3 2.2K Resistor 1/4W
R4 1K Resistor 1/4W
R5 1K Resistor 1/4W
R6 33K Resistor 1/4W
R7 33K Resistor 1/4W
R8 33K Resistor 1/4W
R9 33K Resistor 1/4W
L1 LED VF= ~1.4V
L2 LED VF= ~1.4V
L3 LED VF= ~1.4V
S1 SWITCH SPDT
S2 SWITCH SPDT
FUSE 1/2A Fast Blow
OBD OBD CONNECTOR OF YOUR CHOICE
ORDER SCHEDULE
See the Round 2 thread here:
https://rennlist.com/forums/showthread.php?t=334514
[b]
If you need to reach me, please use the Private Message function instead of email. My email delivery isn't reliable.
And just to reiterate, No warranty of any kind is expressed or implied. No liability will be assumed by anyone if you damage your car, computer, or self. However, there are assembled circuits working on both 964s and 993s (including mine) right now.
Colin
-Colin
Details
Ray's 1995
What you will get
Board specs:
Price
BOM
D1 1N4148 Diode
D2 1N4148 Diode
D3 1N4148 Diode
J1 DB9 FEMALE
R4 1K Resistor 1/4W
R5 1K Resistor 1/4W
L1 LED VF= ~1.4V
L2 LED VF= ~1.4V
L3 LED VF= ~1.4V
S1 SWITCH SPDT
S2 SWITCH SPDT
FUSE 1/2A Fast Blow
ORDER SCHEDULE
[b]
Colin
Last edited by cowtown; 03-05-2007 at 10:41 PM. Reason: Pics updated with latest board rev.
Rally-
Chris Walrod offered to assemble - you should probably ping him and see if you can arrange some sort of assembly line. I'd like to help with assembly, but have used up so much time doing the PCB that I need to take a break from it for a bit.
Jeff-The DougB software is specific to the Porsche OBD. The circuit might or might not work with other models and appropriate software. Try asking raycm (who designed the circuit) in the 993 thread.
Colin
Colin
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Yessir, I can help with assy. In a few days, I can assemble a kit of components to offer as well. These components are best bought in quantity. Buying in bulk will save everyone money. Stay tuned.
Technical Guru
Hi Chris,
I'm in for a fully assembled device. Let me know if you need any unskilled help, running errands, whatever, to get this done. I'm not too far away, in Redlands.
Originally Posted by JasonAndreas
If the PCB is ordered panelized (they precut the boards for you and you have 8"x11" to work with) you can get 8 boards per panel and 2 panels sell for $48USD, 4 panels $78USD, 10 panels $138USD. Double-sided with plated through holes are $78USD, $128USD and $218USD. Shipping 1lb Fedex from Malaysia is only $12USD. We just need to email them a standard Gerber file or I can transfer the schematic to Cadsoft Eagle, etc.
We don't need plated holes or double layer.
Let me know via PM if I can email you the files I have.
Colin
That's a pretty simple board, lots of express shops can do that for a buck a piece or even less, but they need to be panelized so the board shop doesn't have to throw away excess.
