Track pads?
#31
Location: WhippetWorld, .........is it really only this many
1 Post
Originally Posted by Bill Verburg
Chris raises an excellent point.
the cg or CoM won't change very much no matter what you do, corner balance and f/r weight distibution are also items that don't change much from one 993 to another.
I've been reading a good article here brake bias
#32
Are the TT Big Red front and RS rear brakes still fairly front biased?
I'm using the Brembo GT front (355mm) and the RS rear brakes and wondering if I should try Chris' set-up: Yellow in front and Black in back. I've been using the Pagid 4-2-1 compound on the street and track with no ill effects, but wondering if my bias could stand to be shifted to the rear a bit.
Greg H.
Greg H.
#33
IIRC lowering the carby a relatively small amount changes the effects of the CG quite markedly
the most front biased is the 993RS/tt(Big Red) w/ stock 993 rear
next is stock 993
next is 993RS/tt(Big Red) w/ 993tt rear
most rear biased is 993RS/tt(Big Red) w/ 993RS rear
you can juggle bias a bit w/ pads as Chris B has done and w/ p/v and if you are really industrious use the race ABS
#34
King of Cool
Oranges or PFC 97. Both good (although I think PFC 97 slightly better). Next I'll probably go back to PCF 97s or try Blacks or combining different colors.
#35
I used Pagid Oranges until I got to Road America. Switched to Pagid Blacks, which I loved. I've heard that they may be tougher on rotors, but they were much more confidence-inspiring on that high-speed circuit and I'm still using my original rotors.
