993 Forum 1995-1998
graphite gray vs classic gray
Old 04-27-2010, 02:00 AM
pcarhombre
pcarhombre's Avatar
Default graphite gray vs classic gray
Does anyone know how these two colors look next to each other?
Old 04-27-2010, 02:16 AM
Magdaddy
Magdaddy's Avatar
check out the color samples on the link below. Graphite grey was explained to me today as being very dark, just a few shades lighter than black. The sample on the below site, does not confirm that.
Anyway, best I could do...good luck.
http://www.weissachautohaus.com/guide.html
Old 04-27-2010, 02:55 AM
David in LA
David in LA's Avatar
You also have to figure that these cars are now 13-17 years old so there may be some color fade...variance in the same color may actually be more than between different colors, especially for cabs. Ran into the fade issue when I was trying to match carpetting for a RSD kit.
Old 04-27-2010, 11:10 AM
pcarhombre
pcarhombre's Avatar
Thanks guys! Magdaddy, I looked at the link and it confirms what I thought: not much different from each other (even considering the fade issue, David.) I am trying to buy a shift **** +boot from a 996 that is listed as graphite grey and am hoping I can get away with the color being a bit different. Worse case scenario, I'll dye to match. Thanks again.
Old 04-27-2010, 12:02 PM
rol607
rol607's Avatar
The shifter in this photo was orginally black. had it dyed Linen and turned out great.
Quick Reply: graphite gray vs classic gray
