993 Forum 1995-1998
Key Stuck in Ignition...
Old 01-02-2007, 12:44 AM
993Dude
993Dude's Avatar
Originally Posted by chris walrod
Wonder if the steering lock has something to do with this problem? does the key turn easier when wiggling the steering wheel?
No. Wish it were that easy. Looks like I am taking apart the shifter...
Old 01-02-2007, 12:47 AM
993Dude
993Dude's Avatar
Originally Posted by Thaddeus
That sort of improvisational thing would be acceptable if it was a Buick or some such trash, but not a Porsche. Fix it!
Agreed.
Old 01-02-2007, 01:22 AM
fbfisher
fbfisher's Avatar
Note the position of the shift **** button. If it is not protruding all the way up, it means that you have not fully engaged "P" and the key won't come out. Even a slight misalignment will cause this problem. Easily fixed though, make sure it is all the way forward and there is nothing impeading the shifter movement.
Quick Reply: Key Stuck in Ignition...
