Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat
Go Back   Rennlist Discussion Forums > Air/Oil Cooled Technical Discussion Areas > 993 Forum
Sign in using an external account
Register Forgot Password?
Search
Thread Tools Search this Thread
Old 01-01-2007, 01:21 AM   #1
993Dude
993Dude's Avatar
Default Key Stuck in Ignition...
I've only had my '98 993 for a few weeks and I have an issue which may not sound like much but could turn into a headache. When I turn the ingition off, the key won't turn all the way to the left and gets stuck in the off position. I then can't turn it back on or get the key out of the ignition. With patience and quite a bit of jiggling I can get the key out, but then once the key is inserted it won't turn in either direction. I have tried both keys that came with the car with similar result. The steering wheel turns freely in this condition, so its not a matter of the wheel locking against the key.
Questions:
Am I looking at having to replace the keys or the cylinder or both?
Is a cylinder replacement something I can attack myself of is it pretty funky?
Is this a common dilemma?
Thanks for the feedback...
To remove this ad, register today or login if you already are registered!
993Dude is offline   Reply With Quote
Old 01-01-2007, 01:30 AM   #2
rcwelch
rcwelch's Avatar
Perchance do you have a TIP?
Randy
1995 993 Coupe
Iris Blue Metallic
Member 020604-2742
HWFM Official Team Roaster, BBQ Director
rcwelch is offline   Reply With Quote
Old 01-01-2007, 09:44 AM   #3
993Dude
993Dude's Avatar
I do have a Tip...
Old 01-01-2007, 11:06 AM   #4
Simon Shearer
Simon Shearer's Avatar
I've made this mistake a few times with my TIP. Same result each time. As long as you are careful to turn the key to the off position ONLY after selecting PARK, you shouldn't have any problem going forward. If you make a mistake and turn the key to off in DRIVE, or in any other gear, the key will get stuck...
Simon Shearer is offline   Reply With Quote
Old 01-01-2007, 11:07 AM   #5
Thaddeus
Deer Slayer
Thaddeus's Avatar
Do a search on 'key' and 'tiptronic', apparently if the tip's shifter gets out of adjustment it can jack up the ignition lock in the way you describe.
Thaddeus
Thaddeus is offline   Reply With Quote
Old 01-01-2007, 12:39 PM   #6
Marv
Marv's Avatar
I though it was your car's way of saying, "I am not ready to stop now!"
Marv
_____________________
2004 GT3 Guards Red, Black Leather (Carbon Fiber, Xenon, Gold Crest Wheel Caps, Cruise, Painted Console, Porsche Crested Seats, Metal Door Sills, Dev. Stitching Seats)
1996 993 Carrera 2 Arena Red, Gray Leather (Gone and somewhat forgotten )
1990 964 Carrera 4 Guards Red, Black Leather (Way Gone and Forgot)
Marv is offline   Reply With Quote
Old 01-01-2007, 02:03 PM   #7
Chuck W.
Chuck W.'s Avatar
Quote:
Happened to me. Easy fix for someone that knows the cars. Don't mess with the ignition key anymore. You'll just mess it up. The problem isn't there.
Chuck W.
RLM 040430-3522
'01 Boxster S - For Sale
'12 BMW 535I M-Sport European Delivery 12/03/2011
'07 Mini Cooper S
'01 Toyota Tundra SR5
'97 993 Cab - Gone
'97 993 Turbo - Gone
Chuck W. is offline   Reply With Quote
Old 01-01-2007, 02:18 PM   #8
Pete Lenzini
Pete Lenzini's Avatar
I had a similar problem the first time or two I drove mine until my son drove it and mentioned that there is sort of a stiff spring in the ignition switch that allows the key to be turned a few degrees counterclockwise from the "off" position to remove the key. If you are stopping at off and not turning the extra few degrees against the stiff spring, that's your probem. Tey turning just a little bit harder (not hard enough to break something!) and the key should come right out.
HTH
Pete
Pete Lenzini is offline   Reply With Quote
Old 01-01-2007, 03:42 PM   #9
ca993twin
Old Fartus Emeritus
ca993twin's Avatar
Also try a small shot of WD40 in the ignition switch, but the problem most likely is in the gear selector nadjustment.
Steve
Official AARP Representative to "Hey Wait For Me Racing"
RUFUS: 1996 993 Arena Red Ruf Turbo R
WALDO: 1996 993 Arena Red Twin Turbo (Sold)
1997 Mustang Cobra convertible (ex open-track car)
1974 911 Targa (long gone)
1970 911E (became an IMSA GTU/GTO RSR)
ca993twin is offline   Reply With Quote
Old 01-01-2007, 04:34 PM   #10
rcwelch
rcwelch's Avatar
The reason I asked if you had a Tip was that my car did the same thing and the final fix was to remove the switch panels in front of the shifter and adjust the cable linkage of the shifter a little ( it lies just under those panels ). It turned out mine was just a little out of adjustment and by tightening it up, it now works fine...I think it is a 10 or 12mm nut ( double locking). It's pretty easy. PM me if you need more instructions.
Randy
1995 993 Coupe
Iris Blue Metallic
Member 020604-2742
Old 01-01-2007, 08:20 PM   #11
993Dude
993Dude's Avatar
I did all of the above. I got the key out by rocking the car back and forth and "re-shifting" it into park. I also shot the ignition with a bit of WD-40 for good measure. There is clearly a knack to pushing it in slightly while turning the key a bit past noon counterclockwise. Looks like I need to adjust the shifter cable if it keeps up. I am ok doing the shifter dance but I'm not sure the wife will be...
Old 01-01-2007, 09:00 PM   #12
Thaddeus
Deer Slayer
Thaddeus's Avatar
Quote:
That sort of improvisational thing would be acceptable if it was a Buick or some such trash, but not a Porsche. Fix it!
Thaddeus
Old 01-01-2007, 09:08 PM   #13
993BillW
993BillW's Avatar
What, you don't like the idea of reaching around the steering wheel to grab/pull the column shift lever so you can start the car? I think that was the routine in early-70's GM's, correct?
Bill
Thanks to Jager for avatar pic
'97 993 C2 Coupe, Arena Red/Black
'10 Cayenne GTS
'13 VW Golf R (the dog's ride)
past Porsche's....993 cab, '88 911, 968 & 955
993BillW is offline   Reply With Quote
Old 01-01-2007, 09:37 PM   #14
kkim
You might want to consider, as mentioned, adjusting the shifter cables before you wear out the ignition cylinder.
kkim is offline   Reply With Quote
Old 01-01-2007, 09:43 PM   #15
chris walrod
Guru
Rennlist Small
Business Sponsor
chris walrod's Avatar
Wonder if the steering lock has something to do with this problem? does the key turn easier when wiggling the steering wheel?
Is this a great place or what?
Chris
97 993 twin
"Knowledge is what you get when you read the directions, experience is what you get when you don't." - Unknown
Interesting -- yes, it was snowing
chris walrod is offline   Reply With Quote
Paid Advertisement
Tags
1996, 2006, boxster, cobra, convertible, ignition, ignition07, key, keys, mercedes, mini, porsche, removal, sienna, stuck, toyota
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
Copyright ę 1998 - 2007 Rennlist.com
Advertise on Rennlist - Privacy Statement - Terms of Service - Jobs
Emails & Contact Details
