993 Forum 1995-1998
Sponsored by: DashLynx
Brrrrrr - No Heat???!!!
Old 01-18-2007, 12:07 AM
John D.
John D.'s Avatar
Hi Vic..!
PM sent!! THANK YOU!!!!!
Also - I just arrived home from work - and the temps up here are about "-(somethingstupid)". My 993 started right up.... I let her warm up for a few minutes in the parking lot... I turned the heater controls - and.....
I HAD HEAT!!!
I took the long way home...
My thanks to all!
John
Old 01-18-2007, 12:50 AM
MikeAlwaysWins
MikeAlwaysWins's Avatar
This thread reinforces the reason I hang out here so much...... Yes, Tony and Chris...THIS IS A GREAT PLACE!!!
Old 01-18-2007, 02:56 AM
grmnxtc
grmnxtc's Avatar
'Frozen Rotors' to 'Frozen Motors'.....
too funny...
But at least you now have HEAT!
Old 01-18-2007, 05:40 PM
Oxford_Hippo
Oxford_Hippo's Avatar
Cool
Hi JohnD
I've got the same problem in my driver's side footwell ,
any chance you could give me some pointers on how you get to the flap - what sections of carpet ( the trunk release lever? ) carpet etc. I'll need to remove to get to it? / how best to fix it open??
Many thanks
T.
Old 01-18-2007, 05:44 PM
Slow Guy
Slow Guy's Avatar
Originally Posted by Oxford_Hippo
Hi JohnD
Many thanks
T.
Did you see the link that ViperBob posted? I think it is post #3 or 4, it had a good bit of info.
Old 01-18-2007, 06:00 PM
John D.
John D.'s Avatar
Hi JohnD
any chance you could give me some pointers on how you get to the flap - ...
OK - just home (and with heat!!!
It's really easy (even I can do it )
First - on the front trunk release latch - remove the two hex head screws - the latch cover will come off....
Next - the carpeting insert can then be slid to the rear, and released from it's forward catch hook. Just pull it towards you and put aside...
Next - there is a wiring clip holding two wire connectors. Unscrew the 10mm screw - and move that clip aside...
Next - the "flapper and motor" is held in place with two short pieces of air hoses (one from the bottom longitudinal and the other end going into the front trunk air box). There are 4 hose clamps (2 to the flapper and the other two into the longitudinal/air box.). Loosen all four large clamps (8mm socket or screwdriver).
Next - remove the hoses/flapper - and disconnect the wire connector to the motor...
Finally - there are three Phillips head screws holding the motor to the flapper. Remove the screws and withdraw the failed motor unit... Use tape to tape the flapper into the open position (until you get a replacement motor) - and reinstall...
Total time - about 10 minutes..!!!
Hope this helps!!!
John
Old 01-18-2007, 08:22 PM
Oxford_Hippo
Hi, yes looked at the 964 site, from ViperBob's post ( thanks )
but I only checked the drivers side footwell, not the side air vent...so thought footwell fix woudl solve the problem...
But - Nasty feeling now it might be the whole drivers side that is stuck on cold....so will use the 964 link -
will check tomorrow.
Old 01-18-2007, 08:34 PM
John D.
John D.'s Avatar
...But - Nasty feeling now it might be the whole drivers side that is stuck on cold....so will use the 964 link -
Actually - if the flapper is "stuck" (the one I told you how to get to and Eric posted about how to fix my problem ) - YES - the WHOLE drivers side will be cold - as no warm air can get to that side of the cockpit That flapper shuts off all warm air before it reaches the main air/mix box in the front trunk....
John
Quick Reply: Brrrrrr - No Heat???!!!
