993 top end over haul 60K fact or fiction???
#46
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
11.3:1 is the mechanical compression ratio by design, 200 is a dynamic pressure in PSI. These cars tend to range from 180 to 210 psi depending upon condition and warmth of the engine when the test was completed.
1-2% IIRC means the leakdown test showed that amound of static leakage in a percentage which is a great result. IIRC= if I recall correctly.
#47
Still not hearing about the symptoms observed before having to redo the top end. Is it only the compression test or are there other tell tale signs? Because my car had a SCharger put on with about 80000 miles and no known rebuilds, a couple mechanics said I'm driving a time bomb and to be careful taking it to the track,etc. Wonder if they are trying to create work? I'll get a compression test next time I go in the shop.
#48
Knock on plastic but my car has 80k and no motor issues yet. $1500 to fix the top and a couple thousand for the 60k maintenance, dash lights, trunk shocks, etc. And then the most important mods, HD Bilstein MO30 kit and 996 steering wheel. That set me back another couple of thousand but well worth it. I thought the stock steering wheel looked like my wife's SUV steering wheel.
#49
The compression and leakdown tests are a good indication of the overal health of the engine but they don't do much for assessing valve guides, unless of course they are so bad that the valve won't seat properly.
Just drive it!
#50
88k miles and still, touch wood, all OK including shocks and clutch. I thinbk some of the lower mileage US cars go early due to your higher extremes of hot and cold plus the cars not being used enough...
#51
What is the ideal compression because I have nothing to compare your numbers to. I thought the compression was 11.3 to 1, not 200. Sorry I guess I don't understand. Please translate 1-2% IIRC.
#52
RL Technical Advisor
There are two reliable and accurate ways to determine whether one needs an upper-end rebuild or not: oil consumption and leakdown testing.
When oil consumption reaches 700-800 miles per quart (or litre), its time. Guides are worn out, valve stems are worn down to spec, and one usually finds a multitude of assorted oil leaks.
Leakdown testing shows the ability of each cylinder to hold a predetermined pressure and shows the percentage of leakage. Further, leakdown testing shows WHERE the leakage is coming from and thats something compression testing doesn't do. Pressurizing each cylinder while listening to the intake, exhaust pipes, and the oil filler tube tells the technician the general condition of intake valves, exhaust valves, & ring sealing.
I don't think those mechanics were misleading you or trying to generate business and I'd advise regular leakdown tests as well as careful tracking of oil consumption.
