Dyno run - whoah!
Lifetime Member
Lifetime Member
That run looks very simliar to my run on the Dynojet machine. However my peak numbers are low because I did it in 2nd gear instead of the 4th. Also the smoothing function on my graph was not turned on.
Originally Posted by 99three
Did you print the dyno chart? What was you max torque curve? What were the ambient conditions, ie. Temp. and humidity ratio?
If the run was not corrected, then I agree, the ambient conditions could make for a most-favorable run.
Originally Posted by beers4all
Wow - wonder what it would have been with Fabspeed mufflers ...
It seems that 15 HP claim just won't go away....personally, Joe Fabiani has always been very helpful to me. I have had several of his products, the Supercups and the Cat Bypass (For off road only). The construction on the products was excellent and customer service outstanding.
If we are going to throw out some barbs on HP claims, there are quite a few that could go on the list, many of which are NOT sponsors.
