993 Forum 1995-1998
Sponsored by: DashLynx
Dyno run - whoah!
Old 04-04-2007, 11:58 AM
g_murray
g_murray's Avatar
Default Dyno run - whoah!
OK, I DID do a search and most of you - with the 3.6L Varioram - seemed to be averaging 250HP at the wheels... (some of you, as a result, discovered that your Varioram 'flaps' were NOT working...)
Well I got a printout of my post-elite-30,000-mile service ‘dyno run’ – which, I might add, the mechanic did for free (whilst he had the car in his shop).
He did two runs – both using 4th gear.
As we all know, this particular model of 993 has the 3.6L ‘varioram’ engine - which is advertised as 282HP.
Both runs consistently averaged 275HP at the wheels at 6000 rpm (max. on run #2 was 275.3HP) – (before the auto-fuel-shutoff started kicking in close to 6500 rpm).
That’s very LITTLE loss! I'm actually shocked!
I guess it’s because it’s a manual transmission and has a limited slip differential and has always been (to me and the previous owner) known to be an oil-leak-free 'strong' engine. (Plus - new filters, plugs, points, rotors, etc. can only have 'helped').
But heck, I’m STILL impressed!
G.
P.S. And (apart from my recent Bilstein-HD suspension upgrade) she's "stock".
Old 04-04-2007, 12:10 PM
WIMPWGN
WIMPWGN's Avatar
Depending on what dyno was used, results will vary between two different types of dyno.
Old 04-04-2007, 12:13 PM
pcar964
pcar964's Avatar
Good result!
Old 04-04-2007, 12:16 PM
g_murray
g_murray's Avatar
He has a Dastek 1500 horsepower rear wheel chassis dyno.
Old 04-04-2007, 12:18 PM
WIMPWGN
WIMPWGN's Avatar
Great result.
Old 04-04-2007, 12:53 PM
PorscheZen
PorscheZen's Avatar
Congrats! Now get back to work...
901aero
901aero's Avatar
Where you there while he ran the car? Wasn't it great to hear your own car rev up? That was one of the best things I got out of the experience! What a sound!
Old 04-04-2007, 01:03 PM
g_murray
g_murray's Avatar
You're a riot!
Old 04-04-2007, 01:26 PM
beers4all
beers4all's Avatar
Wow - wonder what it would have been with Fabspeed mufflers ...
Old 04-04-2007, 02:06 PM
Slow Guy
Slow Guy's Avatar
The real question....was the engine tray on or off?
Great result.
Old 04-04-2007, 02:33 PM
99three
99three's Avatar
Did you print the dyno chart? What was you max torque curve? What were the ambient conditions, ie. Temp. and humidity ratio? All these are driving result factors. Those are surprisingly good numbers.
Old 04-04-2007, 02:43 PM
g_murray
g_murray's Avatar
Hi,
Yep, I have a *printout* of the dyno run.
I'll scan it and put a link to a jpeg version of it.
I can only surmise that since it happened last weekend - in the NY (LongIsland) area - that ambient temps were around 45-50 deg. F and lowish relative humidity. (He did this in his shop - I don't see any 'environmental conditions' listed.)
Gerry
Old 04-04-2007, 02:57 PM
ZombiePorsche44
ZombiePorsche44's Avatar
That doesn't surprise me, all Blue 993's have the most HP of any 993's produced.....LOL
ZP44
Old 04-04-2007, 04:40 PM
LAT
LAT's Avatar
I only got 251HP because my Cab is heavier
Old 04-04-2007, 07:27 PM
99three
99three's Avatar
Huh...Did you use a 4 wheel dyno?
Quick Reply: Dyno run - whoah!
