strange sound
strange sound
I have a 96 c2 that has a buzzing sound in behind the dash.When the ignition is turned off it continues for a half a minute. What could it be?
Mine does the same. Sometimes for a few seconds after shutdown, other time it stays on for minutes. As long as it doesn't run the battery down, I'm okay with the noise
Its likely the little fan that runs air from the cabin over a temperature sensor. It often runs after shutoff...its also been know to get "stuck" and drain batteries......
Don't worry, your's sounds fine.
Cheers,
Mike
Cheers,
Mike
Technical Guru
Originally Posted by suee
Is it something i can do? or does it have to go to the shop?
