993 Forum 1995-1998
993 disributor drive belt
Old 06-20-2007, 02:03 AM
irisblue
irisblue's Avatar
Thank you to everyone that has offered advice and info re my distributor drive belt enquiry...
Cheers,
Irisblue
Old 06-20-2007, 02:33 AM
Don Plumley
Don Plumley's Avatar
Just hope your bearings are not shot. A$k me how I know...
Old 06-20-2007, 02:43 AM
Monique
Monique's Avatar
Originally Posted by Chris M.
If you don't want to replace the belt yourself you can send the distributor to a guy in Atlanta who does it for $150. He advertises in Panorama and his email address is markc123@bellsouth.net. No affiliation...
Last time I checked a rebuilt from P car was upwards of $700... I might send mine there when time comes...
Old 06-20-2007, 02:53 AM
Mike J
Mike J's Avatar
Originally Posted by rconnon
hmm pelican's site says it's a bosch belt.. i should have checked before installing...
930-602-134-00-M114
Distributor Drive Belt, 911 Carrera 2/4 (1989-94), toothed, 1 per car
Brand: Bosch
I don't think you got the wrong part...it seemed to fit well and I assume your car is running fine. Oh, I get it, you wanted to see the brand / number on the belt. Yeah, we slipped it in pretty quick once it got rolling!
Cheers,
Mike
Old 06-20-2007, 01:28 PM
rconnon
rconnon's Avatar
Cheers,
Mike
Ya i was more referring to Jason's post about belt manufacturer. cars running fantastic... seems the cap/rotor also made a difference.
Thanks again DrJ.
Old 06-29-2007, 01:55 PM
AX993
AX993's Avatar
Hey All,
Has anyone found a better belt than the Gates one for sale anywhere ? The one I got from Pelican last week were marked Gates. Maybe Gates is the only one makeing them now ? And does anyone have the part number info for the bearings (hoping I won't need 'em, but good info to have handy).
TIA
Glenn
Old 06-29-2007, 06:16 PM
maximo993
maximo993's Avatar
is the same of 964
Porsche (OE)/OEM
Distributor Drive Gear; Toothed Belt between Distributors
For 964 and 993 models with dual ignition distributors. 1 per car.
http://www.autohausaz.com/search/pro...er=93060213400
Old 06-30-2007, 02:03 PM
AX993
AX993's Avatar
Maximo993,
Is Autohaus's belt a Porsche or Bosch item? When I blow up their website photo, it has the same markings as the Gates belt I just got.
Glenn
Old 06-30-2007, 02:15 PM
95 C4 993
95 C4 993's Avatar
I paid $350 to have mine rebuilt. Fair price, in my opinion, considering is something I didnt remove, send off, or have to reinstall.
Old 06-30-2007, 03:05 PM
grmnxtc
grmnxtc's Avatar
Originally Posted by glenn '88 944S
Maximo993,
Glenn
It's a Gates belt... at least my last one was
Old 07-02-2007, 03:31 PM
AX993
AX993's Avatar
SOOOO,
I take it that no one has had any luck finding a dist belt made by someone other than Gates ?.? I'm still looking for bearing part numbers if anyone has them. Thanks,
Glenn
Old 07-02-2007, 05:42 PM
Rick Lee
Rick Lee's Avatar
I sent mine to Mark Cohen, linked in an above post, and he mailed me a rebuilt one beforehand, so my car wouldn't be down long. I just sent him mine as soon as I had installed his. Best $150 I ever spent.
Old 09-08-2007, 04:57 PM
JimGinKC
JimGinKC's Avatar
ok - I went out to remove the distributors to send to Mark in Atlanta, and according to the 993DIY you just put a 24mm wrench on the fan nut to turn the engine. Well, I guess I need new belts because the pulley just spins on the belt. Any other ideas about how to rotate the engine by hand?
Old 09-08-2007, 05:12 PM
Monique
Monique's Avatar
Put in second or third gear and push the car forward.
Good luck
Old 09-08-2007, 05:23 PM
chris walrod
Guru
Rennlist Small
Business Sponsor
chris walrod's Avatar
Or, while turning the alt pulley, squeeze one of the belts around the pulley with your other hand to increase friction. Make sure the car is not in gear
Quick Reply: 993 disributor drive belt
