993 Forum 1995-1998
CEL SAI Code - Port Flush in Seattle ?
Old 07-11-2007, 02:32 AM
jfk308
jfk308's Avatar
Default CEL SAI Code - Port Flush in Seattle ?
Has anyone had any port flush success with any shops in Seattle after getting the CEL SAI code? I checked with Akers, but they don't think the procedure has a very high success rate.
Old 07-11-2007, 11:58 AM
mhm993
mhm993's Avatar
When in doubt....drive to Portland and see Steve W.
Old 07-11-2007, 12:36 PM
C4S_fan
C4S_fan's Avatar
Most of the east side shops that I know of aren't even familar with the technique.. they seem to prefer the more expensive remedy.
Old 07-11-2007, 12:41 PM
TomF
TomF's Avatar
I have seen the same thing as Dennis. The Seattle shops would rather do invasive surgery. I would make a trip to Portland to see Steve W. and stay at the Kennedy Schoolhouse...
Old 07-11-2007, 12:42 PM
TomF
TomF's Avatar
I am going to see John Walker sometime this week and I will ask him if he knows any shops up here that can do the flush with a degree of skill. I am assuming that John doesn't do them...
Old 07-11-2007, 01:44 PM
jimhsu
jimhsu's Avatar
Isn't Kevin on this forum on the east side, in Bellevue?
Old 07-11-2007, 04:39 PM
Jack Esposito
Jack Esposito's Avatar
Try CHRIS'S GERMAN AUTO SERVICE
I hear they have a method for doing it successfully.
Jack
Old 07-11-2007, 08:39 PM
rdurff
rdurff's Avatar
Hi Folks,
Yes, Chris's German Auto is experienced in this. They have even gone beyond the standard fluid flush and created a sort of roto-router device to help with the process. They're also the friendliest Porsche shop I've ever been in, so they'll be happy to talk to you about their methodology.
I was actually at Chris's earlier this week and discussed their process at length. While replacing a lower valve cover gasket, they checked on my passages and it looks like I will need to do this before too long. (My car is currently around 65k miles; so far no Check Engine light.)
In any case, give them a call or stop by.
-Robert
Old 07-12-2007, 03:17 PM
Royalcarrera
Royalcarrera's Avatar
Hi Robert, do you have the phone number for Chris German auto. So far no light either but with 75000 miles on my 96 coupe might be time. Royal NOT A USER, membership #000917-2094
Old 07-12-2007, 04:58 PM
henkinc
henkinc's Avatar
Are all of you folks assuming the flush will hold for any length of time, or are you just trying to pass an emissions test. If it is not a glogged valve (which it could be) you run a real chance of this just recurring if you have some valve guide wear (which we all do)..
Quick Reply: CEL SAI Code - Port Flush in Seattle ?
