993 Forum 1995-1998
Sponsored by: DashLynx
Top End Rebuilds -I'm Confused
Old 10-11-2007, 08:48 PM
matt777
matt777's Avatar
Default Top End Rebuilds -I'm Confused
I look at a lot of ads for 993's and I don't recall seeing one mention of a top end rebuild. How real is this valve guide wear problem? Are people just living with the oil consumption? Any thoughts would be appreciated. Thks. Matt
Old 10-11-2007, 09:20 PM
Mark Wilson
Mark Wilson's Avatar
Mine had a warranty top end at 36K miles for excessive oil consumption and cel.
Old 10-11-2007, 09:22 PM
Texas993
Texas993's Avatar
In some cases the cars have had a top end and don't want to advertise it, other cases they need a top end rebuild, and in most cases they don't need one at all. The CEL is what gets most people to do a top end so they can pass emissions testing.
My car (85k miles) had a top end rebuild at 77k miles.
The valve guide issue is very real, but it depends on how the car was driven. A compression/leakdown test is the best indicator of valve guide wear/leaks. [EDIT: The experts say I am wrong about this.]
Old 10-11-2007, 09:38 PM
Crimson Nape Racing
Crimson Nape Racing's Avatar
compression or leak down tests will not show valve guide wear. The only way to tell is oil consumption, which you cannot test for.....
Old 10-11-2007, 10:14 PM
jimbo3
jimbo3's Avatar
+1. You could run it up to near red line in 2nd gear and look in the rear view mirror for a puff of smoke when you suddenly let off the throttle. It's not a definative test, but indicative.
Old 10-11-2007, 10:21 PM
cmoss
Guest
Posts: n/a
the play in the valve guides can also be measured...
mine was done at ~65K
Old 10-11-2007, 10:26 PM
melman911
melman911's Avatar
What does a top end rebuild usually run?
Old 10-11-2007, 10:29 PM
TRINITONY
TRINITONY's Avatar
4 - 6 k..
only real way according to one of the pros on here, is to do the 'wiggle test'.
Old 10-12-2007, 12:54 AM
vjd3
vjd3's Avatar
I had mine done (58k miles) for $3500, huge difference, car runs great, has not used a drop of oil in 7000 miles. The mechanic showed me the guides, they were totally shot.
Old 10-12-2007, 02:08 AM
luvmy356
luvmy356's Avatar
Originally Posted by pjconner
In some cases the cars have had a top end and don't want to advertise it...
Why wouldn't a seller advertise the top end rebuild? That with all the receipts were the only reason I bought my Targa.
According to the receipts, mine was done at 69k, and since the motor was out, they replaced all the clutch components even though it was still good, plus they pulled the cylinders, resealed the bottom of motor and new through bolts and seals. My motor is bone dry. No rings but the compression was 195-200psi across all cylinders when I just did the 90k service, so hopefully that means the rings are still good.
Old 10-12-2007, 02:44 AM
Napa Valley Realtor
Napa Valley Realtor's Avatar
Originally Posted by TRINITONY
4 - 6 k..
My big question is if the top end rebuild fixes the problem? ie do they use better guides (different) when they do the rebuild, or is the same thing going to happen in another 50k?
Old 10-12-2007, 03:36 AM
Butzi
Butzi's Avatar
Depends who did it & what parts they used.
Most on this board will suggest to use aftermarket (non-OEM/Porsche) guides (bronze something). I would propose that Steve Weiner is one of the experts here, so I'll direct you to his website: http://www.rennsportsystems.com/1.html Scroll half way down to the "A Word about Rebuilt-Overhauled Engines" section.
Also, a search of Steve's posts, with "valve guides bronze" as the subject results in MANY hits. Here's one: https://rennlist.com/forums/showthre...+guides+bronze
Old 10-12-2007, 01:16 PM
dcdude
dcdude's Avatar
And if any oil does bypass your new hard valve guides, you gotta drive it hard to keep stuff from hanging around in the secondary air injection system. Some say cruising around 4K RPM as well (boy, THERE was a discussion!)
Few things in life are certain, but if you do the above, you've done your due diligence, which is all you can do, which is the only way all of us Type As can sleep at night. Hmmm...P-car therapist? There's a career idea!
Old 10-12-2007, 04:10 PM
Adrienne
Adrienne's Avatar
My story is about the same: I did my rebuild about 30k+ miles ago. It still does not burn oil. I (meaning, my mechanic) installed non-OEM guides. Runs like a champ at 143k miles now!!
Old 10-12-2007, 07:01 PM
Nuff
Nuff's Avatar
I just got a '95 993. While I was looking, I saw a few ads that advertised a top end rebuild ....
Quick Reply: Top End Rebuilds -I'm Confused
