Front License Plate
I'm Still Jenny
Actually, I found this.
http://www.stillen.com/product.asp?i...T01&c=EX&m=all
It's designed for 350Z/G35, but it comes in different lengths/widths, so there may be a size that fits your car.
I'm Still Jenny
Wow. I just got a ticket for this. And just bought one from the MowerDeck site. Thanks for the useful tip!
Michael
Michael
If the tow hook isn't ur thing u can also get the plate mounted down lower off the nose by using Jeff's bracket from "inventiva concepts"
In a police state like nj I feel like its a good in between.
My fault I butchered the name, not listed on his sight but I was lucky enough and he made one for me when I emailed him.
http://inventivaconcepts.com/air-1.html
the plate will fit in the center of the lower grill on a turbo bumper cover. You can cut or fold the plate to fit the space, or simply cut off the little brackets that the grill insert clips onto. You need to remove the cover to cut the clips. A very clean look.
While technically, the plate is partially obscured...you should have no trouble.
