Using 6th gear?
Using 6th gear?
I'm relatively new to the world of manual transmissions
Had my p-car for 6 months and this is the first time I regularly drive manual
Occasionally I get into 6th gear when cruising on the highway at ~85mph to cut down on noise on a long trip (for my wife...)
Just curious if anyone actually uses 6th gear...and when
On the highway I go 1st , 2nd (oops, too fast), 6th.
Seems 3rd, 4th, and 5th are kind of optional.
I use 6th for economy and cruising at 80 mph.
Use the gear that is right for the job.
Is there a 6th gear?
Even at 85mph, the RPM's are so low on 6th gear that I keep it on 5th. 100 mph and over...then I go to 6th. This is off course at the track....
I use it for above 80mph cruising. It's pretty much useless for any speeds below that, since you'll be taching under 3k.
