Heat with headers
Heat with headers
Hi guys,
do you know of any way to redirect heat inside the cabin when you have headers on which mean no heat exchangers?
Build a cuff around the header, add a cold air intake with a manually actuated closing flapper valve, a small fan in a cooler area to draw air in and pipe it through the existing ducting.
Install a carbon monoxide monitor!!!
Good luck with the concept
I also remember reading somewhere and i just dont seem to find it anywhere now, that someone used the heat from the oil cooler! Not very efficient for sure, but its a race car and I'm just looking to kind of take the edge out of cold mornings up here.
Getting heat from the oil cooler wouldn't do much good until the oil cooler switched open, which isn't until the car is totally warmed up.
Seems the best solution would be to build a box around your headers, just like the factory did. You already have the ducts and everything for that arrangement, so why not use it.
Kind of like a heat muff used on airplanes? i was thinking about that but the carbon monoxide issue I think its a bit much! LOL... Unless you weld short of a heater box around one pipe it and use the normal heater blower creating a closed circuit just like stock? I attach a pic from an aircraft heat muff which is what I'm thinking.
