Clanging noise coming from right tailpipe
I see your dog is attracted to the sound
Are all the clamps tight ? (3 pcs on each muffler).
if they are tight I would try to remove the muffler and shake it to see if the internals have come loose (although i have not heard of that happening).
Mr. Excitement
Might be a bad cat. They can get loose inside the pipe if they overheat and distort.
Have someone gently bang on the tail pipes while you look and listen for sounds and or loose fittings.
I had a noise too, but it may be different than what you describe. One of the spot welds on the exhaust tip broke, so when I was at idle, the tip shield would rattle around and make a noise. Shop welded it back on (for free).
Seared
