Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat
Go Back   Rennlist Discussion Forums > Air/Oil Cooled Technical Discussion Areas > 993 Forum
Sign in using an external account
Register Forgot Password?
Search
Thread Tools Search this Thread
Old 11-17-2008, 04:20 PM   #1
BobbyT
BobbyT's Avatar
Default Screech/Squeal on start-up
I'm getting a screech/squeal noise that occurs just on start-up for a second or so. I thought it was the alternator failing, so I replaced it. No joy.
The belts have about 20,000 miles on them. They are all correct Porsche OEM, and the tension is correct when checked with the Krikit tool.
When the belts are removed, the fan and alternator each rotate smoothly and easily. The fan blades are not contacting the housing.
The noise is still there with the fan belt sensor removed.
Any ideas on what to check next?
BobbyT #050110-5596
AKA bob@pelicanparts.com
1995 C2 coupe six-speed, Guards Red/Cashmere
2000 Lexus RX300
2012 Mercedes-Benz E350
Fondly remembered:
1969 912 coupe silver
1971 911T Targa silver
1972 914 tangerine
1977 924 copper metallic
1983 911SC coupe guards red
2001 Boxster black
BobbyT is offline   Reply With Quote
Old 11-17-2008, 04:25 PM   #2
John D.
John D.'s Avatar
I would change the belts anyway - because if they are glazed - it will happen..? Since the alternator is new - it's not the bearing..??
Hmmm..???
John
'95 993 C4
'89 964 C4 (<- Jen's...)
'88 911 Turbo
'68 911 L (<- Jen's...)
Don't Panic - it's just me, John D.(<- Jen's...) posting as me....
Team Geek & Sunday Driver for “Hey, Wait For Me Racing”
Giving new meaning to the term “Frozen Rotors”
John D. is offline   Reply With Quote
Old 11-17-2008, 05:10 PM   #3
SC2993
SC2993's Avatar
That's what my belts did just before disintegrating! Only on start up and when very cold.
JK
Bilstein HD's, H & R Springs, Euro Turbo Front Bumper, Scrape Bar, Fog Lights w/ Ducts, Clear Corners, XM Radio, MY 02 18" Wheels, Steering Rack Brace, Aluminum Gauge Bezels.
SC2993 is offline   Reply With Quote
Old 11-17-2008, 05:13 PM   #4
Mike J
Mike J's Avatar
Have you tried a belt dressing yet? I find that sometimes works.
Cheers,
Mike
"Scarlett" - 1997 993 Arena Red Turbo - Sport seats, silver gauges, aluminum parking brake/shifter, 19" RUFs - and more to come.
Gone but now living just down the street - 96 993 Polar Silver Targa
Check out http://www.pcarworkshop.com
Mike J is offline   Reply With Quote
Old 11-17-2008, 05:14 PM   #5
TheOtherEric
TheOtherEric's Avatar
I'd have to guess belts.
His: 1995 993 C2, speed yellow. JRZs, RS sways, other go-fast parts.
His & hers: 1994/5 BMW E36 M3 race car, NASA GTS3.
TheOtherEric is offline   Reply With Quote
Old 11-17-2008, 05:38 PM   #6
Stealth 993
Stealth 993's Avatar
Mine does it after she gets a bath, it's the belts.
Mike S
SIGN UP PNW 993's
1995 993 C4 is SOLD!
Stealth 993 is offline   Reply With Quote
Old 11-17-2008, 07:15 PM   #7
BobbyT
BobbyT's Avatar
Thanks, John,
I was thinking the same thing, but before I do that I think I will just remove the AC belt and see if the noise goes away. Maybe the AC compressor is getting ready to pack it in, rotational resistance is getting higher, and makes the belt slip just a bit on start-up. I'll let you know what I find.
BobbyT #050110-5596
2000 Lexus RX300
Fondly remembered:
1972 914 tangerine
2001 Boxster black
Old 11-17-2008, 07:20 PM   #8
BobbyT
BobbyT's Avatar
Okay, it's not the belts, or anything related. I removed each belt in turn, and then started the engine briefly after each removal, but the noise persisted, even with AC, fan, and alternator belts gone. The noise is a screech/squeal, about as annoying as sharp fingernails on a chalkboard, and seems to come from the top center of the engine, forward of the alternator. It lasts just a second or so. SAI pump? HELP!
Side benefit, I think I can change these belts blindfolded on a galloping horse.
BobbyT #050110-5596
2000 Lexus RX300
Fondly remembered:
1972 914 tangerine
2001 Boxster black
Old 11-17-2008, 07:22 PM   #9
BobbyT
BobbyT's Avatar
Is there a way to disable the SAI pump temporarily to see if the noise goes away?
BobbyT #050110-5596
2000 Lexus RX300
Fondly remembered:
1972 914 tangerine
2001 Boxster black
Old 11-17-2008, 07:25 PM   #10
Stealth 993
Quote:
Blown SAI pumps sound like a high pitch whistle, or a screeching type noise.
If you wait 2min the pump shuts off, or if you have a Durmetric cable you can turn it off & on on demand. You can even turn it on with the engine off.
Mike S
SIGN UP PNW 993's
Old 11-17-2008, 07:26 PM   #11
cabrio993
cabrio993's Avatar
maybe the steering pump and/or belt? Belt is ribbed, but worth checking...
It's right next to the SAI valve and close to the general area where you hear the noise.
RLM#: 050220-5787
96 993 Cabriolet
- H&R Springs, Bilstein HD shocks, Rennline Strut brace, 18" Turbo wheels, Hardwire Passport 8500/remote, Alu bezel rings, Raid 340mm Daytona steering wheel, Alu/Carbon Brake lever, Alu/Leather shifter, RSR exahust, Big Oval tips, Short Shift and more to come...
13 Audi S4 Prestige 6MT Sport Diff.
07 Lexus RX-350 - "Mom Mobile"
cabrio993 is offline   Reply With Quote
Old 11-17-2008, 08:33 PM   #12
Boeing 717
Boeing 717's Avatar
My Car does it too but i just put brand new belts in. I figure they just need to be tensioned some.
JERRY
2007 997 Turbo
2005 955 Cayenne
Previously owned
1991 964 Turbo
1987 944
Boeing 717 is online now   Reply With Quote
Old 11-18-2008, 01:43 AM   #13
BobbyT
BobbyT's Avatar
I don't think it can be the power steering pump belt. Isn't it unlikely to make a noise when the car is still? More likely to make noise when the steering wheel is being moved? Also, the location of the noise seems to be more in the center of the engine, not on the right side, where the PS pump is.
BobbyT #050110-5596
2000 Lexus RX300
Fondly remembered:
1972 914 tangerine
2001 Boxster black
Old 11-18-2008, 09:26 AM   #14
wolfgang1
wolfgang1's Avatar
I had that problem too... for me it was the fan roller belt.
http://p-car.com/diy/roller/
wolfgang1 is offline   Reply With Quote
Old 11-18-2008, 11:54 AM   #15
BobbyT
BobbyT's Avatar
I removed the fuse for the SAI pump (as well as the relay), noise still present. So far I know it is not the fan belt sensor, not the belts, not anything belt-driven. This is a puzzle...
BobbyT #050110-5596
2000 Lexus RX300
Fondly remembered:
1972 914 tangerine
2001 Boxster black
Tags
a4, audi, boxster, cold, engine, hvac, lexus, pump, rx300, sai, screech, squeal, squealing, start, startup, subaru
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
Copyright © 1998 - 2007 Rennlist.com
Advertise on Rennlist - Terms of Service - Privacy Policy - Jobs
Emails & Contact Details
