993 Forum 1995-1998
Sponsored by: DashLynx
Starting Problem
Old 12-21-2008, 12:29 PM
Bob - 95 993/C2
Bob - 95 993/C2's Avatar
Default Starting Problem
Hello,
Been away and car has been garaged and not driven for 6 months. Good cranking on well charged battery and plenty of gas. No start.
Ideas?
Thank you!
Bob
Old 12-21-2008, 12:58 PM
chris walrod
Guru
Rennlist Small
Business Sponsor
chris walrod's Avatar
I have to say try the DME relay first. Its almost a cliche but seems to be a very common and easy fix.
Old 12-21-2008, 01:10 PM
Bob - 95 993/C2
Thanks for the idea Chris. I tried that first with no luck.
(If you've seen the DIY pics that have been around for years on the net on the DME replacement, that was my post to Robin's site a long time ago.)
Old 12-21-2008, 01:33 PM
chris walrod
Guru
Rennlist Small
Business Sponsor
Ahh, I see.
No imobilizer on the 1995 car, however some late builds had this, does yours?
Do you smell fuel after cranking for some time?
Old 12-21-2008, 01:34 PM
Bob - 95 993/C2
BTW, I did use Adrian's idea of removing oil when storing the car and adding some back before try to start.
Old 12-21-2008, 01:42 PM
Bob - 95 993/C2
No gas smell after extended cranking.
Old 12-21-2008, 01:48 PM
chris walrod
Guru
Rennlist Small
Business Sponsor
You can bypass the DME relay to check for fuel pump 'humming'. Wonder if the fuel pump is stuck?
Otherwise, you can remove a fuel line to check for flow.
This may sound silly, years ago I had an 911 SC. I went to Austria for two weeks but before leaving, I pulled the coil wire, a poor mans alarm Anyhow, I got back and went to start the car. ****, it just kept cranking. Then it hit me like a ton of bricks... Any chance?
Old 12-21-2008, 02:03 PM
Bob - 95 993/C2
I don't hear it, Chris... the car has to be cranking for it to be energized if I remember correctly? And definitely don't hear it when cranking and listening up front. I don't have a way to get access to the pump to put a hand on it unfortunately.
Old 12-21-2008, 02:19 PM
chris walrod
Guru
Rennlist Small
Business Sponsor
Without the noise of the engine running, once bypassed, you will hear the pump running.
Old 12-21-2008, 02:26 PM
Bob - 95 993/C2
How do I bypass it?
Sorry to be such a pain... appreciate the help.
Old 12-21-2008, 03:18 PM
RS man
RS man's Avatar
Battery (are you sure it is well charged?) otherwise try new fuel pump relay?
Harry
Old 12-21-2008, 03:20 PM
chris walrod
Guru
Rennlist Small
Business Sponsor
Originally Posted by RS man
Battery.
Harry
Bob says it cranks like normal.
Old 12-21-2008, 03:22 PM
Bob - 95 993/C2
Harry... battery has been on bat tender the entire time and I've run it down and charged it a couple of times in this process. My charger also has a "start engine" mode which I've tried with no luck. Does that still sound like battery?
With bat fully charged it turns the motor just fine.
Thanks!
Old 12-21-2008, 03:59 PM
Bob - 95 993/C2
Chris,
Would pulling the dme relay and jumping between pin 30 and 37 (3 and 7 on CES) do the trick?
Trouble is I don't have access to anything but a piece of wire to do the jump...no ent caps or fuse-protection on the jump wire. Thinking maybe that may not be a smart idea given what I've got to use.
What do you and others think?
On my other car I'd just juse a paper clip!
update: just looked at doing this...forget it. Unless there is a way to do it at the DME/fuel pump relay the procedure I suggested is a no go.
Old 12-21-2008, 04:14 PM
Bob - 95 993/C2
Henry... the DME relay is a DME/FUEL relay on the 95 and I've tried a new one of those already. Also checked the fuelpump fuse and it's okay.
Quick Reply: Starting Problem
