993 Forum 1995-1998
Sponsored by: DashLynx
1997 PORSCHE 993 TURBO X50
Old 08-13-2016, 10:27 AM
  #46
1990ruf
1990ruf's Avatar
Default x50
Is this thred still alive?
Old 09-18-2016, 03:41 AM
  #47
chicabum
chicabum's Avatar
Lots of confusion about the X50 for the 993T. Some because it was also available for the 996.
424HP is the same as the turbo S, just 16 HP more than standard turbo. I always thought 16HP
was a silly upgrade.
The 16HP (Less than 4% increase in Power) are easily achievable with overboost and I don’t think it really needs the extra radiator.
I had the impression X50 was always, at 450, more powerful than TurboS. Didn’t know about the x50 424HP.
I always liked the regular turbo wing better…
About availability for different years, you need to remember that the ECUs were different from 97 on, so if parameters needed to be adjusted, on a 97 and later that would be a few minutes job and depending on what needed to be adjusted for 96 or 95, it could need some hardware replacement on the ecu.
Even the first gt2 had around these HP figures.
These different figures went all around because is was “so easy” to extract more power of that engine, and because the engine could take it so well.
I don’t know if you could order it new or had to add it later and I don’t think the factory would open back doors…
As far as I know there were different version of the 993T for US, ROW and Brazil. I have the Vin numbers somewhere.
Additionally there were different equipments for 27 different countries.
The Story of the army guy in Germany … I heard a thousand variations of that same story to explain discrepancies in Porsches. Forget it.
Old 09-19-2016, 09:52 AM
  #48
1990ruf
1990ruf's Avatar
Default x50
I own a 1997 X50. (450) HP.
Old 09-19-2016, 10:59 AM
  #49
chicabum
chicabum's Avatar
1990ruf,
Anyway you think about it, 450 is the ultimate iteration of air cooled Porches.
for the X50, did you have K16 or K24?
Old 09-19-2016, 11:13 AM
  #50
lambotex
lambotex's Avatar
my 96 also had the 450hp X50 kit. It is K24 turbos, extra oil cooler and different ECU. This was sold as a dealer install option.
Old 09-19-2016, 11:37 PM
  #51
kcphuah
kcphuah's Avatar
I have a ROW 1997 with factory X50 installed, extra oil cooler and etc but how do you tell if the X50 option has 450hp or 424hp?
Old 09-19-2016, 11:45 PM
  #52
DiegoR
DiegoR's Avatar
AFAIK is:
408cv
430cv
450cv
You can check the turbos and and the DME P/N to see if they are the bigger turbos and correct DME for 450cv option. If so (450cv) most likely was upgraded at some point.
Maybe if you run the VIN for options, then it can tell you if your car was equipped with the X50 (430cv) power package or not. Although, not sure if the X50 came with the extra oil cooler or this was a separate option...at least in mine the X50 and the extra oil cooler are different option codes listed in my VIN.
430CV = K16 turbos + reprogrammed DME
450CV = K24 turbos + reprogrammed DME (different than 430 CV DME)
Old 09-20-2016, 01:23 PM
  #53
1990ruf
1990ruf's Avatar
Originally Posted by eciiaia
i was interested in the car but i think was overpriced ... but is a beauty
I have one ill sell you. True x50. PM me.
Old 03-17-2024, 10:40 PM
  #54
Burzel55
Burzel55's Avatar
Bringing up this old thread,
Does anyone know production numbers on RoW 1997 Turbo with X50 (430hp) package?
Thank yo for any information
Old 03-18-2024, 11:15 AM
  #55
JB 911
JB 911's Avatar
By the option sticker code. X50 has 430 PS. XLC has 450PS. Sorry the answer took a while
1996
286
1997
ROW 359
US 11
1998
48
Old 03-18-2024, 07:26 PM
  #56
C4Spolar
C4Spolar's Avatar
This is the 993tt XLC 450hp package minus the oil cooler only for 1998 993tt model. The ECU ending with P/N 85 is the 450hp power maker for 1998 only, ECU ending with P/N 83 is the 430hp for 1997, both works with K24 turbos.
Old 03-18-2024, 11:02 PM
  #57
Burzel55
Burzel55's Avatar
1996
286
1997
ROW 359
US 11
1998
48
Thanks for the quick reply. Can I ask where you found that information? Car is great and love learning more about it
Old 03-19-2024, 10:11 AM
  #58
JB 911
JB 911's Avatar
Absolutely. The book is Porsche 911 turbo AIR-COOLED YEARS by Gabriel-Franz. It's was a limited edition and sold out but they pop up on e-bay every once in a while - that's where I found mine.
Quick Reply: 1997 PORSCHE 993 TURBO X50
