Is it possible to service or replace the A/C expansion valve w/o removing fuel tank?
My Air Conditioning system will not hold a charge. There is a lot of dye visible on the expansion valve that would indicate failed O-rings.
I've looked at the DIY on Pcarworkshop.com:
http://www.pcarworkshop.com/index.ph...orator_Replace
and this job is well beyond my capablity.
Has anyone successfully serviced or even replaced the expansion valve without removing the fuel tank? Can you pull out the fire wall without removing the fuel tank?
Thanks!
Jim
Thanks!
Jim
Jim,
Others will prob chime in, but after doing mine, I don't believe you can pull the expansion valve with the firewall in place, and you can't remove the firewall with the tank in place. It's not as horrible a job as it looks, just takes a LOT of time for just those O-rings. If you can change the oil & filters, spark-plugs & wires on your 993, you should be able to do the job. As with the oil and spark-plugs, you just need lots of patience.
HTH
Glenn
HTH
Glenn
Removing the tank is really not as bad as you would think. Draining the fuel is the worst part (a little messy). If the tank is almost empty, then not tood bad at all. The rest is pretty straight forward. Still a pain overall though.
If you are talking strictly expansion valve and not removing the evaporator, you can get to it by removing the expansion tank on top of the fuel tank and removing the firewall. I was able to remove the firewall without taking the entire tank out, just the expansion tank on top.
Could all these posts about replacing the evaporator be fixed with just replacing the expansion valve? Has Chet from Austin figured out a loophole in that you can just replace the $50 expansion valve (including O rings) without removing the entire gas tank + airbox? It sure would save a lot of diy time (or labor) to be able to remove only the expansion gas tank to gain access to the expansion valve. Thoughts?
You can remove the firewall without touching the expansion gas tank. Trickier, but I just did it!
You need a second set of hands to hold the fuse panel up, while you pull the firewall straight up.
Hi Jim,
I re-built my AC system two summers ago... so if you want to tackle it with some local help, or borrow any AC tools let me know! As Johan mentioned, it is possible to replace the expansion valve without removing the vapor tank... I recall having less trouble/more room there than under the front bumper replacing the ballast Rs and condenser.
Cheers, Mark.
Cheers, Mark.
