Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat | marketplace
Go Back   Rennlist Discussion Forums > Air/Oil Cooled Technical Discussion Areas > 993 Forum
Old 08-29-2009, 12:59 PM   #16
boulderbobo
boulderbobo's Avatar
Quote:
Originally Posted by MarkD View Post
If you feel nothing (very loose, no resistance at all) it is likely the little e-clip came off and the shift rod dropped off of the shift lever. That clip has to be in it's groove and if it is not seated completely... well, this happens.
I could see how this could happen easily. When I installed mine, I checked that clip more than once to make sure it was in the groove.
Duckman, It should be an easy fix. GL!
Bob-
081107-96021996 = Ultra TOP SECRET NUMBER for IB eyes only.
GR C2/Black
2001 Audi S4 - Highly modded 175 k miles
2001 Toyota Land Cruiser - aka "the bus"
2005 BMW R1200GS - Big Red
boulderbobo is offline   Reply With Quote
Old 08-29-2009, 02:14 PM   #17
nicknack
User
What does this cost?
nicknack is offline   Reply With Quote
Old 08-29-2009, 06:53 PM   #18
Warpig
Warpig's Avatar
Duckman! That stinks... please let us know what you find.
Very fortunate to have this happen in your garage.
I had a similar problem where I could move the shift lever in a complete square of it's outermost reach. I could however get full forward into 3rd and full back into 4th. Turns out my cup/bushing guess was wrong and I really didn't need the SSK & Golden Rod (but I'm glad I got them anyway) what happened with my 993 is that the trans shaft set bolt had fallen out and was sitting in the rubber boot. I was able to shift 3rd/4th because the boot was pulling and pushing the shaft in/out on the trans. I could have just re-installed the shaft set bolt. But I didn't. I put the SSK & Golden Rod in anyway.
Glad I did.
Nick
95' 993 L92M Polar Silver Metallic
139 - Seat Heating - Left
220 - Locking Differential
224 - Active Brake Differential
340 - Seat Heating - Right
398 - Left Outside Mirror - Electric - Plain
454 - Automatic Speed Control
650 - Sunroof
C02 - Equipped With Catalytic Converter
XD4 - Porsche Crest Rim Caps
Fister DiPietro Motorsports Short Shift Kit
Fister DiPietro Motorsports Golden Rod
Eibach Springs & Bilstein HD's
Warpig is offline   Reply With Quote
Old 09-03-2009, 04:48 PM   #19
Duckman
Duckman's Avatar
Send a message via AIM to Duckman
Problem solved. Rather than it being the clip, it was the bolt. It came loose and I found it on the floor of the garage under my 993.
My mechanic, who is normally really good about most things, fixed it without charge, as he should have. This time he drilled and wired the bolt so the nut cannot come loose.
I'm still amazed at my luck for the problem to occur in my garage, rather than on the road. It would have been bad enough to get stuck somewhere out in the boonies but it could have been even worse. Imagine dropping the throttle at the apex and drifting toward the exit edge at 90 mph or so when your tranny pops out of gear. It could ruin your whole day.
Duckman
'95 993 coupe: Gurards Red with Cashmere; 6-speed; heated hard-back sport seats; three-spoke 996 steering wheel; Big Reds; Bilstein HD shocks; H&R springs; 18" Sport Classic II wheels; strut tower brace; computer chip; custom exhaust; FDM-SSK w/ Golden Rod.
Duckman is offline   Reply With Quote
Old 09-03-2009, 05:10 PM   #20
boulderbobo
Quote:
Track Ready
Bob-
GR C2/Black
Old 09-03-2009, 07:08 PM   #21
cohare
cohare's Avatar
Quote:
I second this question!
cohare is offline   Reply With Quote
Old 09-03-2009, 07:21 PM   #22
tjangi
tjangi's Avatar
http://www.fdmotorsports.net/index_files/Page489.htm
A must have in my mind...
1995 993 C2, Midnight blue/Cashmere
Mods: Protomotive Stage 1 Turbo, FDM SSK and GR, WEVO Motor Mounts, H+R Supercup Coilovers, BBS RS-GT, Wood Shifter, Silver Gauge dials, 996 3 spoke steering wheel, RS Door-cards, HID, LED Driving Lights, Euro Rear and Euro Front Turbo Bumpers.
tjangi is offline   Reply With Quote
Old 11-07-2009, 11:06 PM   #23
larpy
larpy's Avatar
I just finished installing my SSK and Golden Rod tonight. It took me about 1.5 hours but I do have a lift in the garage which reduces time. This is a very easy upgrade. While is was there I replaced the rear seal on the transmission tale which was leaking. It was an $8 part from Pelican. Big difference between the old set up and the new one! Thanks FD Motorsports. You guys as usual have been great to deal with!
1997 993 Cabriolet, 26,000 miles
Rennlist Member 091012-0493
PSS10, Fister D Golden Rod & SS Kit, HID headlights, MY02 rims & more "stuff" in boxes!
Best Carpet Cleaning Service In Colorado
larpy is offline   Reply With Quote
Old 11-08-2009, 11:39 AM   #24
MarkD
MarkD's Avatar
Quote:
Awesome, glad you got it installed... thanks for the kind words Chris!
_______________
Mark
97 993 turbo Black/Black - 2WD, Kinesis K28s, PSS9s, 2WD trans mount, FDM SSK, etc.
993 Turbo Exhaust Video: http://www.youtube.com/watch?v=dQzfJm9eGLw
96 993 Cab Blue Turq/Grey - M033/Bilsteins, Fister Stage II Exhaust
06 Cayenne S - Family Truckster
'57 Speedster replica by Vintage Speedsters - Yellow, 2.0l Engine by Lyle Cherry
'07 Mini Cooper S
MarkD is offline   Reply With Quote
Old 11-08-2009, 12:58 PM   #25
96PorscheTwinTurbo
96PorscheTwinTurbo's Avatar
On the AWD cars it is not a bolt in kit. The front mount point is affixed to the torque tube. You also need to create some room on the center tunnel cover for the lower position of the RS lever (since the shift box is actually the torque tube, there are no bughings to reconfigure, see more in the install guide here: http://www.fdmotorsports.net/SSK%20DIY.pdf The bushings you see that need to be flipped are not there on a C4).
Michael nailed it... the most cost effective route are the Porsche RS parts and modifying the lever.
Thanks for the nice comments Bob, Jason and Michael. We are doing our best and having a pretty good time doing this stuff!
Mark,
Can you clarify? I'm not quite sure if you're indicating the AWD is a bit more involved installation. Would love to consider on my TT. I'm not a mechanic but great at puzzles so unless modifications or special tools are required, I'm usually pretty capable of moderate difficulty tasks. And like a few others here, would love to know of the cost. Feel free to PM me.
Steve
Steve
Good Memories:
1966 Corvette Conv - sadly gone
1970 Corvette LT1 - one of the best - sold
Other Corvettes - 1984, 1977, 1974 conv., 1974 -sold
1966 Riviera - a classic style car - sold
In the future:
Sunbeam Tiger
993 RUF Turbo R
96PorscheTwinTurbo is offline   Reply With Quote
Old 11-08-2009, 03:03 PM   #26
boulderbobo
Nice!
Can't wait to check it out.
Bob-
GR C2/Black
Old 11-08-2009, 03:10 PM   #27
larpy
larpy's Avatar
Quote:
Originally Posted by boulderbobo View Post
Nice!
Bob-
R U back yet?
Old 11-08-2009, 03:36 PM   #28
boulderbobo
R U back yet?
Not yet. Just got into Istanbul.
This place is wild.
Bob-
GR C2/Black
Old 11-08-2009, 07:05 PM   #29
MarkD
MarkD's Avatar
Quote:
Originally Posted by 96PorscheTwinTurbo View Post
Mark,
Steve
Steve,
We are in the midst of developing a SSK for the AWD cars but still have some testing to do.
We could set you up with a kit now but this requires modifying the tunnel cover for clearance. The AWD cars use the torque tube as the shift box and the front drive shaft runs down the middle of the tibe the shifter slides on so it cannot be moved upward as you do with the 2WD cars.
What we are working on is eliminating the need to either pound out or cut/weld the tunnel cover so that the RS lever will fit. It is going to be very close!
Worst case, this kit will still require a modification to the tunnel cover panel but it will be much less.
We also want to eliminate at least one of the ball/socket joints since this can be a weak point.
If you want more info feel free to shoot us an email fdmotorsports@comcast.net
Or I'd be happy to talk and explain what, how, why, etc.
_______________
Mark
'07 Mini Cooper S
Old 11-08-2009, 07:06 PM   #30
MarkD
MarkD's Avatar
This place is wild.
Bob-
We aren't in Kansas any more Toto
Have fun!
_______________
Mark
'07 Mini Cooper S
Tags
2001, 993, audi, cayenne, fd, fdm, forum, gts, install, kit, motorsports, s4, shift, shifter, short, throw
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 1998 - 2007, Rennlist.com
Advertise on Rennlist - Terms of Service - Privacy Policy - Jobs
