993 Forum 1995-1998
Sponsored by: DashLynx
Brake Piston Seal Grease?
Old 07-01-2009, 03:53 PM
CaptainGSR
CaptainGSR's Avatar
Question Brake Piston Seal Grease?
I am rebuilding brake calipers on an Acura. I might as well buy grease that I'll be able to use on the Porsche Seals in the future.
I need to grease the Brake Piston Rubber Seals. It is hard to find much info on this. So far, I found an old Honda Service Bulletin that recommends: Dow Corning 111 Silicone Paste on brake system seals (supposedly very good for suspension bushings BTW!).
The Porsche 993 Service Manual does not have much on Brake Caliper Rebuilding. It does mention: Unsilikon TK44 N2 Brake Cylinder Paste 000.043.117.00. Is that to lubricate the rubber seals too?
What do you "Gurus" like to use?
Cheers,
Old 07-01-2009, 04:19 PM
chris walrod
Guru
Rennlist Small
Business Sponsor
chris walrod's Avatar
Dow 111 is great for this. But the 111 might cost more than the caliper seals themselves!
Old 07-01-2009, 04:20 PM
chris walrod
Guru
Rennlist Small
Business Sponsor
Tilton Engineering offers assembly grease as well, in much smaller tubes.
Quick Reply: Brake Piston Seal Grease?
