classifieds |
membership |
rennlist |
photo album     sponsors | upload photo | chat | marketplace     |
| Register | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars | My Recent Topics | Vendor Directory |
Thread Tools |
#1 |
Rennlist Member Join Date: Jun 2006
Hey guys,
I have '96 993 and my parking brake needed adjusting. It wouldn't hold until the 5th or 6th click. I followed the instuctions in the manual but when I got to the part where I pull up on the brake 2 clicks and tighten the adjuster nut, I run out of threads for the nut. In other words, I can't get the parking brake cables tight enough to stop the wheels from turning. Does this mean I may need new cables or can I put a couple of washers in front of the adjusting nut to give it some length. Any thoughts are appreciated. Thanks, Bob
'96 993 C2 silver/black |
#2 |
Rennlist Member Join Date: Aug 2004
Possibly need new parking brake shoes? Pull your rear disks and give em a look.
RLM#: 041015-4811 98 Arctic c2s |
#3 |
Rennlist Member Join Date: Sep 2003
Be sure that the "nipple" (#25) is in front of the adjusting nut (#26). Probably it is, but it will change the dynamic if it dropped down sometime when the lever was removed. (graphic below)
http://dcauto.gotdns.com/illustration/index/858597570 |
#4 |
Rennlist Member Join Date: Oct 2003
When you followed the WSM instructions, after backing off the adjuster at the lever to give the cables slack, did the adjuster at the drum/disc move enough to lock up hub rotation?
If so, back off a click or two on that adjuster, pull up the handbrake 2 clicks & tighten the cable adjuster.
'96 993 C4S Midnight blue , Bilstein HD, M030 bars & turbo springs, FPB, SSK, wide ovals w. LPMM, 8"/11" 'hollows', Schnell brace '80 928 Copper brown 5-sp, Konis, euro S springs/brakes, CS wheels, S4 wing '88 928 Euro, Nougat brown, GTS rear, Konis, BBS .... sold ... '90 535i 5-sp black, Bilsteins/Dinan, 3-pc wheels, .. |
#5 |
Thanks for the suggestions. In response, Raptor - yes, the "nipple" #25 is still there; Garth S - the hubs did lock up with the adjuster at the drum/disc after I loosened the cables. However, after I backed off on this adjuster and pulled up on the handbrake 2 clicks, I couldn't get the cables tight enough to lock up the hubs. Ppressle - I will check the parking brake shoes next.
Thanks, Bob
#6 | |
Quote:
) .... perhaps if a 1/2" or so spacer were cut from a piece of 3/8" pipe and placed behind the nut, it would effectively lenghten the threaded zone for adjustment?
| Tags |
| 914, 96, 993, 997, adjust, adjusting, adjustment, brake, cables, emergency, parking, porsche, raptor, shoe, yukon |
| Thread Tools | |
