Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat | marketplace
Go Back   Rennlist Discussion Forums > Air/Oil Cooled Technical Discussion Areas > 993 Forum
Old 09-19-2009, 01:05 PM   #1
TheOtherEric
TheOtherEric's Avatar
Default My Protomotive Stage 1 twin turbo kit is for sale.
[EDIT 12/11/09: As I posted below, in response to questions about the turbo's condition, I'll just send the turbos out for teardown, inspection, and cleanup. That way you can be assured they're in excellent condition.]
Finally got it listed. Ad is here.
EDIT: sorry, I forgot non-members can't see that link, so here's the ad:
My Protomotive Stage 1 twin turbo kit for 993 is for sale. I purchased the kit new in 2008 and it only has around 1,800 miles on it. Currently sitting on a shelf. New price is $14,500 ($14k kit plus $500 injectors), so I'd like to get $8,800 for it. Kit has been installed and is FULLY sorted, which is a huge advantage over starting from scratch (trust me!).
I got +135 hp (flywheel) using pump gas. Only adds 47 lbs over stock. This is a true bolt-on kit (no need to drop the engine) and includes:
- Garrett T3 Super60 turbos
- Intercooler
- BOVs
- Modified headers (heat exchangers)
- Tial wastegates
- Alum valve covers
- Larger fuel injectors
- Adjustable fuel pressure regulator
- etc. All you'll need is a chip (but I'll include my 91 and 93 chips). Protomotive will custom write a chip for $110 for this kit. Just tell them what you want/need.
The kit is a cat-free setup with a muffler. 1995 cars won't get a CEL, but 96+ cars may want a work-around (like an O2 sensor spacer, or remove the O2 sensor and put it in a box... same as the guys who use cat bypasses) else you'll likely get a CEL. A pic:
I spent a lot to upgrade to a ss muffler, and added tips:
P'motive sells a slightly cheaper kit that retains stock cat and has no muffler, however that's far from ideal as you really want the turbos at the headers and no muffler would be too loud, hence this configuration. This kit is easily good for 500 hp if you install different pistons to lower the compression ratio.
The sale includes a complete set of DIY instructions written by me:
964 Owners:
Protomotive tells me this should fit a 964 except that there probably wouldn't be enough room under the rear bumper covers. So either some modding would be needed, or it would probably fit a turbo body.
I'm glad to answer any questions about it. Here is a good thread describing the choice between supercharging and turbocharging.
1995 993 C2, speed yellow. Protomotive Stage 1 Turbo Kit For Sale
TheOtherEric is offline   Reply With Quote
Old 09-19-2009, 01:13 PM   #2
CornerCarver
Send a message via AIM to CornerCarver
I'll take it! Oh wait. I sold my 993.
This is a great deal! Good luck with the sale. For that price it is worth getting into the motor and lowering compression to up it to stage 2.
What a deal.
Al
Past rides:
02 996 X Koni
95 993 C2
97 E36 M3
95 993 C4
95 E36 M3
90 E30 M3
LocoDeMoto.com
CornerCarver is offline   Reply With Quote
Old 09-19-2009, 02:39 PM   #3
No HTwo O
Eric, who in the Chicago area could do the install? About what should take cost in addition to your kit? Thanks.
No HTwo O is offline   Reply With Quote
Old 09-19-2009, 07:16 PM   #4
TheOtherEric
i just included the ad above for the non-members.
Quote:
My guy in Franklin Park would surely do it (Andy at Eurocar). Not sure what he'd charge, probably between 20 and 30 hours at $85 (?) per hour, so probably $2k give or take. He's already very familiar with the kit since he does all my work. If you ship your car to Protomotive, they charge $2,500 for install. Using my instructions, anybody could do it, no special tools needed and no electrical rigging.
Old 09-20-2009, 01:40 AM   #5
CP
CP's Avatar
Eric,
Why are you selling? Just curious.
CP
993 RUF BTR-2
2007 Cayman, Meteor Gray
Rennlist membership #031217-4871. Yiiiippeee!!!
CP is offline   Reply With Quote
Old 09-20-2009, 09:00 AM   #6
No HTwo O
Quote:
Originally Posted by CP View Post
Eric,
CP
Sad story:
http://forums.rennlist.com/rennforum...gine-dang.html
Old 09-20-2009, 01:39 PM   #7
CP
CP's Avatar
Weep. Sad indeed.
I read that thread but did not make the mental connection. Thanks for the refresher course.
Eric,
Best of luck with the sale and the rebuild.
CP
993 RUF BTR-2
Old 12-01-2009, 11:20 PM   #8
kb
kb's Avatar
Eric -
I am really tempted by your kit. Do I need a new engine lid or does it all fit in giving a stealth look? Thanks. Gil
1995 993 C2 Aventurine Green (Build date 2/94); Clear Bra; KLA strut bar; 6000k HID; RS Clutch; LWF; Turbo S ducts; Gerts FPB; Clear Corners; Bilstein HD w/ H&R; Aerokit 1b; Cyntex chip; RS Splitters; B&B SS Exhaust; Tach RPM Mod;
kb is offline   Reply With Quote
Old 12-01-2009, 11:54 PM   #9
Nollie
Nollie's Avatar
Quote:
Originally Posted by kb View Post
Eric -
Eric's kit needs a turbo tail of some sort (GT2, turbo S, turbo) to accommodate the intercooler. I'm constantly tempted by this deal, Eric went through all the trouble to sort it out http://forums.rennlist.com/rennforum...stall-diy.html
==Dan==
96 C4-2S Outside the range of stock specification
Nollie is offline   Reply With Quote
Old 12-01-2009, 11:55 PM   #10
TheOtherEric
Eric -
The stock lid doesn't fit over the monster intercooler, so you need a turbo wing, GT2 wing, or Turbo S wing. RS lid wouldn't do it, since you need a larger opening. I would consider selling my Turbo S wing (I bought it new from MA Shaw/ Geddy), but I haven't really thought that idea through.
Edit: Dan beat me by a minute.
Old 12-02-2009, 12:00 AM   #11
TheOtherEric
p.s. have I mentioned +135 fwhp lately?
I do think that whoever buys this kit will feel like they got away with murder.
Old 12-02-2009, 12:30 AM   #12
kb
kb's Avatar
Eric -
I can only imagine the additional power. How was it to drive? Acceleration in 3rd and 4th gears?
Old 12-02-2009, 12:48 AM   #13
TheOtherEric
Eric -
Driving it, you don't get turbo lag since it's still high compression, so that's really nice. When the turbos start boosting (3k to 3.5k), the thrust isn't jerky and fiendish, but rather smooth. So that makes it very drivable... it's like the stock car but a LOT faster. And the torque never peters out (see the dyno plot I posted). Many turbo cars (like our Audi) have pretty narrow torque bands, and it peters out higher in the rev range (5000 rpm in the Audi). But these turbos just keep pulling. They're sized for 500 hp if you install lower compression pistons at some point down the road.
Acceleration in 2nd gear is easily my favorite, but passing on the highway in 3rd or 4th gear is quite the pleasure.
Old 12-02-2009, 12:47 PM   #14
vhanzon
vhanzon's Avatar
Send a message via MSN to vhanzon
Why do you guys keep bumping this thread?? Eric's kit is NOT for sale .
I wish you all the best Eric and a speedy recovery for your engine. Tell your wife
you want new rods etc. for christmas, that'll get you started ..
Viggo
'97 993TT - "The Black Pearl" -
Past Porsches:
'98 993TT Arena red - Museum Piece - "Last of the air cooled" - Gone
'97 993 C2S Vesuvius - All stock - 25.000 mile GQ - Gone
'97 993 C2S Vesuvius - All stock - 100.000 mile Beater - Gone to France
vhanzon is offline   Reply With Quote
Old 12-02-2009, 12:57 PM   #15
BSL
BSL's Avatar
I would SO take this if I would be able to walk/drive/breathe (or just plain be alive) after my wife found out I bought it...
Brian
'95 993 C2 Cab
Past:
'09 Cayenne
'07 C2 Cab
'06 Boxster
BSL is offline   Reply With Quote
Tags
1995, 964, 993, 996, cayman, kit, porsche, pricing, promotive, protomotive, sale, stage, stage1, turbo, twin
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 1998 - 2007, Rennlist.com
Advertise on Rennlist - Terms of Service - Privacy Policy - Jobs
