Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat | marketplace
Go Back   Rennlist Discussion Forums > Air/Oil Cooled Technical Discussion Areas > 993 Forum
Old 11-05-2009, 03:13 AM   #16
944/951guy
944/951guy's Avatar
Does a optima battery need a new bracket? or does the stock on fit?
Yellow or Red top and why?
Current Cars:
1996 Porsche 993 C2. ABD/LSD, Black on Cashmere, HID's, Stage II's, Big Ovals, Rennline Harness Bar, Turbo Twist Wheels and more coming..........
1994 Toyota T100, Work Truck.
Previous Cars Worth Mentioning:
1986 Porsche 944 Turbo
1995 Porsche 968
2007 Subaru Sti
1990 Nissan 300ZX Twin Turbo
2000 Honda S2000
944/951guy is offline   Reply With Quote
Old 11-05-2009, 03:05 PM   #17
Edward
Addicted Specialist
Edward's Avatar
I have been through many batteries, over many cars, over many many years (decades ...hmmm, that makes me old ). I've come to the very easy conclusion that for a street car, there is no such thing as a "performance" or "better" battery. You can pay more ...that is easy. But you won't get more. Get one that fits right, the proper CCA for your useage, and one with a 3-4 year warranty and you're good. I've had Optimas fail in 1-2, had costco and autozones go up to 4 years ...just no correlation between what you pay and longevity. In my experience, all that battery marketing hype amounts to you paying more.
Edward
Support your local Rennlister: Pay it forward.
1995 Carrera Coupe - Guards Red and Grinning
1982 911SC Track Meister-in-Progress
HWFM Proud!!
RennMember 020407-3788
Edward is offline   Reply With Quote
Old 11-05-2009, 03:35 PM   #18
Dick in TN
Optima Red Top in my Porsche is 10 years old.
Have an Odessey in my BMW M/C, like it too.
Dick Scales
'97 993tt Arena Red/Classic Grey
Dick in TN is offline   Reply With Quote
Old 11-05-2009, 04:03 PM   #19
2Many Cars
User
2Many Cars's Avatar
+1 It matters more how the battery is treated. Regardless of liquid or gel type the chemistry isn't all that different. Frequent cycling (drained to full charge) wears any battery out. If you're not using the car much keep a high quality floating charger on it, avoid deep discharges (like leaving your lights on...duh!), and if appropriate keep the electrolyte level topped up - if you do then even a cheap battery should last for years. To me the only justification for an Optima/Oddessey is the acid spillage issue, which shouldn't be an issue as long as the battery is properly vented and secured (an assuming you keep the shiney side up of course).
2Many Cars is offline   Reply With Quote
Old 11-06-2009, 02:27 AM   #20
pcar
pcar's Avatar
I tend to leave my car sitting for 2-3 weeks at a time and because of this I have killed two optima red tops over a 4 year span. Even when the Batteries were new it would be hit or miss after a few weeks. i dont have access to a power outlet so the use of a battery tender is out of the question. I gave up on the Optimas and went with this http://www.remybattery.com/Products/...y__9AGM48.aspx after reading some good reviews for some other listers. I jumped in the car after it sat for 5 weeks and it spun-up like a champ-I know I need to drive more!
pcar is offline   Reply With Quote
Old 11-06-2009, 04:27 AM   #21
Tuner1
Tuner1's Avatar
Quote:
Originally Posted by Dave911G View Post
I got my Odyssey 925T (that T is important) from Battery X-Change on Canyon Rd in Beaverton about a year ago for $170. The factory bracket won't work. Add a Rennline bracket for another $100 and you have just spent a ton of money to loose about 11 lbs from the front of the car. i
It all depends on how fanatical you are about performance or OCD about the details If you have a stock(ish) 993 that is only driven on the street then stick with an OEM replacement battery.
I would be happy to shed weight off my car at the rate of $15/lb without giving up anything except having to use a battery tender for long parking intervals. Odyssey here I come
Tuner1 is offline   Reply With Quote
Old 11-06-2009, 11:38 AM   #22
Noah
Noah's Avatar
The weight loss with an Odyssey is quite a bit more than 11 pounds. The stock battery is 50-55 pounds, the Odyssey is 25.
Black 1996 C2 with PSS9's and stuff
Noah is offline   Reply With Quote
Old 11-06-2009, 12:38 PM   #23
Tuner1
Tuner1's Avatar
Quote:
I was using the # given by the previous poster. At that rate my weight saving cost goes down to only $7/lb. What a deal!
Old 11-06-2009, 01:01 PM   #24
Noah
Noah's Avatar
Ed Zachary. I'm going to do an Odyssey as well, when it comes time for a new battery.
Old 11-06-2009, 02:46 PM   #25
944/951guy
944/951guy's Avatar
I weighted my stock battery yesterday and it was 43lbs.
Red top optima was 33lbs.
Current Cars:
1995 Porsche 968
2007 Subaru Sti
2000 Honda S2000
Old 11-06-2009, 03:00 PM   #26
2Many Cars
User
2Many Cars's Avatar
That sounds more realistic. The battery for my 300D diesel might be 55 lbs - it's a fair amount bigger with much more CC amps - but not the standard 993 battery.
Old 11-06-2009, 03:07 PM   #27
Noah
Noah's Avatar
Ah, I must be thinking about the older 911 batteries. Those were huge.
Old 11-06-2009, 03:22 PM   #28
Tuner1
Tuner1's Avatar
I used this one in my 930 and it performed very well, even during the occasional -10C cold start! Only 21lbs.
http://www.braillebattery.com/index....tteries/b3121/
Old 11-07-2009, 01:44 AM   #29
shu
shu's Avatar
the braille battery seem to be reasonable in price, might have to give it a try!
1997 C4S, Arena Red, Cashmere, Bilstein HD's w/H&R springs, RS Tail, Clear Corners, Gert's FPB, 996tt Hollow Spokes, V1, HID's, Focal VRS, JVC AVX77, RS Motor Mounts.
shu is offline   Reply With Quote
Old 11-07-2009, 04:15 AM   #30
Edward
Addicted Specialist
Edward's Avatar
Quote:
OK, I'll bite: with the MSRP at $179, which part of that is "reasonable"??
Oh well, to each his own.
Edward
HWFM Proud!!
Tags
1996, 944, 95, 993, auto, batteries, battery, interstate, lightweight, optima, or, porsche, portland, replacement, toyota
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 1998 - 2007, Rennlist.com
Advertise on Rennlist - Terms of Service - Privacy Policy - Jobs
