classifieds |
membership |
rennlist |
photo album     sponsors | upload photo | chat | marketplace     |
| Register | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars | My Recent Topics | Vendor Directory |
Thread Tools |
#61 | ||
Rennlist Member Join Date: Mar 2009
Quote:
Quote:
'95 993 C2 [Polar/Black] ... |
#62 | |
Damon also posted the following in the other thread [ http://forums.rennlist.com/rennforum...ggerita-6.html ]
Quote:
#63 |
Rennlist Member Rennlist Site Sponsor Join Date: Sep 2003
KEWEL. Just tonight I was looking at those at Tire Rack.
'96 993TT, '02 Z06, '03 986S |
#64 |
Rennlist Member Join Date: Jun 2007
I have a set of Enkie NT03s on my 993 right now. I have my winter tires on them, but I originally ran my MPSC on them at the track. They performed very well. My only complaint would be the silly looking bar that runs around the rim about an inch down the spokes--I think it clutters up the lines of the wheel. Oh, and I cannot for the life of me figure out why they have two value stems. Since I put my winter tires on the Enkies I need a new set of track wheels, and I was thinking those blue Alleggeritas would look pretty wild...
#65 |
Rennlist Member Join Date: Sep 2009
The 2 valve stems are for purging the air in the tire. Common practice for hardcore track people with either dried air or nitrogen.
#66 |
Thanks Evan.
When you purge the air do you force air in one side and out the other, or just suck the air out of both? |
#67 |
Well the way I have seen it done is with a system like this http://www.intercomp-racing.com/Prod...SYSTEM_737.cfm
or you can just fill and bleed to zero repeatedly by hand, it just takes longer. I don't really know why you would need or want two valve stems to do it (I have never had a wheel with 2 valve stems) but that is what they are market as for. I believe with two stems you can fill from one and bleed from the other simultaneously, displacing the air you have decided you don't like in the tire. I am not so sure Nitrogen is really all it is cracked up to be though. The bottle the team I was crewing for was using was supposedly medical grade and it still had a 10psi change cold to hot, which is only a few psi better than dry air. |
#68 |
Rennlist Member Join Date: May 2006
With Satin Black center caps......
1997 993, Factory RS Aero Kit, Guards Red/Black w/Cashmere |
#69 |
Rennlist Member Join Date: Mar 2004
Where did you get the center caps and black bolts (or probably nuts in your case)?
#70 | |
Quote:
#71 |
Rennlist Site Sponsor Join Date: Mar 2006
Blue is special order. Approx. 6 weeks.
damon@tirerack.com 800-428-8355 ext. 643 **Don't forget to add my name to online orders!** Or use this link: http://www.tirerack.com/affiliates/l...sp?AFFCODE=AQ5 |
#72 |
Rennlist Member |
For what it's worth, I picked up a set of these from Tire Rack with R6s mounted for next year's track season. Weights (for just the wheels) are:
18x8.5 = 18.166 lbs 18x12 = 23.446 lbs I'd wanted the orange, but apparently it'll be April before they do another run of that color, so I settled for black and I figure I'll get them painted when it's time for the next set of tires.
'07 GT3 RS |
#73 |
Rennlist Member Join Date: Aug 2006
I believe that MY02s and Turbo Twists are both made by BBS. I assume that they are cast, not forged. Does that mean that they are not suitable for track use?
Chuck '96 911 C2 coupe 6-speed Midnight Blue. 29K on new top end, ROW MO30, Bilstein HDs, MY02s, Fister Stage III, RS strut bar, Walrod bushings, Rennline dead pedal and fire bottle mount, FPB, LSD, ABD, Exclusiv XC9 XC32 options rootwood shift + e-brake |
#74 |
Rennlist Member |
These look fantastic on your car. Simply awesome.
'96 993 C2, Black/Cashmere: RS Short Shifter, Bilstein HD's with M030 springs and F/R M030 sway bars, FPB, Big Ovals, Engine Tray Delete, New clutch w/RS single mass flywheel, Fister Stage III exhaust |
#75 |
Rennlist Member Join Date: Jan 2004
Quote:
Bill '97 993 C2 Coupe, Arena Red/Black '06 Carmon Red Pepper "S" '97 BMW M3/4/5 '97 Arena Red/Gray 993 Cab (sold) '93 968 Coupe (sold) |
| Tags |
| 10, 130, 18, 18x8, 48, 5114, 5130, bbs, bmw, enkei, m3, nt03, oz, rgr, sale, wheel, wheels |
| Thread Tools | |
