Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat | marketplace
Go Back   Rennlist Discussion Forums > Air/Oil Cooled Technical Discussion Areas > 993 Forum
Old 11-06-2009, 07:18 PM   #1
arenared911cab
arenared911cab's Avatar
Default R&R Pad Rotor Question...
I'm starting my Pad/Rotor replacement today, and will be painting the calipers. Is there any reason to keep the brake line attatched if I plan a complete flushing once finished? Is there some sort of hidden nightmare if I disconnect? Or is it simply reconnecting and doing a complete flush?
Rob
_______________________________
'96 Arenared Cab (my happy place)
'08 Chrys Pacifica (family hauler)
"The best view..."
arenared911cab is offline   Reply With Quote
Old 11-06-2009, 07:55 PM   #2
trophy
trophy's Avatar
No reason, just be sure you clean it before undoing to ensure absolutly no crap gets into the caliper.
Steven
Now
1995 993 C2 - KW Clubsport Coilovers, TRG Sway Bars, Custom Droplinks, OMP Strut Brace, Walrod Bushings, DasSport Rollbar, Big Reds, Custom Mufflers, Cup Air Box, Steve Wong Chip, HID's, OMP Carbon Seats, 8.5" & 10" Forgelines.
2002 BMW 330 Ci - Daily Driver
Then
2000 Subaru STI
1982 924 Turbo (First Porsche, sadly missed)
1973 914-6
1972 914
trophy is offline   Reply With Quote
Old 11-06-2009, 08:32 PM   #3
NC TRACKRAT
NC TRACKRAT's Avatar
I have been told that if air gets into the ABS, it can be an unholy bitch to bleed. Personally, I would avoid it or, at least, plug the brake line fittings as soon as you disconnect to avoid air backing up into the system.
1995 993 Carrera Coupe Black/Black 13k mi. FABSPEED, ltd. slip, Nakamichi/McIntosh/MBQuart
1998 993 C2S Red/Black, 41k mi. PSS9, FABSPEED,RS Bars, CDR210
Other vehicles: 2003 MINI Cooper S, 2005 MINI Cooper S, 1965 Shelby GT350, 1966 Shelby GT350, 2000 F250 SD.
NC TRACKRAT is offline   Reply With Quote
Old 11-06-2009, 10:11 PM   #4
Mike J
Mike J's Avatar
I have done it both ways, found that disconnecting the line from the calipet (if its not been off) is a challenge. Make sure you have a GOOD flare wrench. You also need a rubber plug to plug the brake line from leaking out all the fluid, and as was said, on the ABD or ABS gets air, lots of trouble to get it all out again.
IMHO, its not worth the trouble...paint the calipers on the car, change the pads, and drive it.
Cheers,
Mike
Mike
96 993 Targa - Polar Silver
Euro Turbo Bumper, RS Tail, PSS-9's, RS Sways, Sparco Seats, DIY rebuilt engine, RS Clutch/Flywheel, RS Pulley, new Targa roof, HID Lights, DIY Hella turbo duct lights, 1.5" LPMM's, 19" RUFs, 340mm Atiwe steering wheel, deleted bumperettes (front/back), deleted headlight washers, Split Grill, ***whew**
Check out http://www.pcarworkshop.com
Mike J is offline   Reply With Quote
Old 11-07-2009, 02:58 AM   #5
arenared911cab
Sooooooo lets just say I have a freind who also owns a 993 and is also doing the brakes (I know!!!... quite the coincidence, huh) that tried to plug the line but apparently (so he tells me) he didn't do a good enough job and let the reservoir drain...I know, what kind of dummy would do that!
So I can pass this info to him,
1)what are the odds the abs has air
2)Wht do I ...does he...do about it
He would very much appreciate any assistance
Rob
"The best view..."
Old 11-07-2009, 03:41 AM   #6
ReinerFink
ReinerFink's Avatar
Get friendly with a dealer. Do the best you can bleeding via the normal procedure. Then drive car to dealer. Remove RR wheel, attach catch bottle to bleeder screw, open it, attach pressure bleeder. Hook up the Hammer/PST2/PWIS/PWIS2 to the ODB port and tell the ABS pump to "bleed". It will activate and run for 45 seconds or so and in the process pump about 12oz of brake fluid out of the RR caliper.
-reiner
ReinerFink is offline   Reply With Quote
Old 11-07-2009, 04:44 PM   #7
arenared911cab
ReinerFink, A previous post mentioned you can turn ignition on then off the start up abs pump, then bleed, and do this several times to accomplish the same thing, does that make sense? We don't have a dealer in Kelowna, so I need DIT solutions. I have power bleeder and lots of time...
Rob
"The best view..."
Old 11-08-2009, 01:48 PM   #8
NC TRACKRAT
If your "friend" has plenty of fresh brake fluid and plenty of time, what the heck, give it a try! Maybe it didn't get so low as to get air in the ABS. Don't forget, if the fluid level got down too far, the clutch slave cylinder may also have air in the system. You'll find out soon enough.
Old 11-08-2009, 03:13 PM   #9
arenared911cab
Since its a Tip, doesn't that elliminate the clutch slave thing...and does it make a difference as to what wheel...And now that I've done this will it make much differenceif I take off the rest of the calipers, or will that just compound my air issues. Since I'm in a wheelchair, I decided to take off the caliper to paint as it would be difficult to paint "on the car". So ideally I'd like to take the remaining calipers off, one at a time, plug the lines properly, then bleed the heck out of it using cheap DOT 4 and then finish of with the good stuff. Does this throw up any red flags for anyone?
Rob
"The best view..."
Old 11-08-2009, 03:30 PM   #10
ReinerFink
ReinerFink's Avatar
[quote=arenared911cab;7055653]ReinerFink, A previous post mentioned you can turn ignition on then off the start up abs pumpQUOTE]
The only way I know to get the ABS pump to run is to have the proper PST2/PWIS computer to tell it to run, or to go romp on the brake pedal at 30mph and get the abs to kick in.
When you turn the ignition on a in an AWD car and you hear a "bzzzzzzz" noise, that is the hydraulic brake booster pump putting pressure into the accumulator. That is not the ABS pump, which will only run when its told to by the ABS computer (when wheel speeds are mismatched).
I have heard of people doing a normal bleed, then driving around and getting into the ABS, and then doing another bleed. I haven't tried that so can't tell you how effective it is.
-reiner
Old 11-08-2009, 03:55 PM   #11
Steve Weiner-Rennsport Systems
Technical Specialist
Lifetime Member
JMHO, but you either need to plug the lines to prevent the MC & ABS unit from getting air or have access to a Hammer or PST-2 to properly bleed the system.
Sounds like the former idea would be easier, given your location.
Steve Weiner
Rennsport Systems
Portland Oregon
503.244.0990
For Performance Parts and Upgrades, Machine Shop Services, & Technical Information, visit us on the Internet at:
http://www.rennsportsystems.com
E-mail: porsche@rennsportsystems.com
Steve Weiner-Rennsport Systems is offline   Reply With Quote
Old 11-08-2009, 04:58 PM   #12
jimq
Burgled
jimq's Avatar
Send a message via Yahoo to jimq
All you need to do is wedge the brake pedal down with a piece of wood between the pedal and the seat or something similar and the fluid wont drain out of the open lines.
jim
Conservatives....We work hard so you don't have to
91 White C2 Cab tiptronic
03 Black 996TT X-50 Grocery getter
2002 Dodge Ram 5.9L Gas Hog
Bend-Pak Scissor Lift
64 230SL Mercedes (SOLD after 18 years )
Some other Porsche's
jimq is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 1998 - 2007, Rennlist.com
Advertise on Rennlist - Terms of Service - Privacy Policy - Jobs
